Fueling Failure
Old Nov 2, 2013 | 01:16 PM
JagGroupLLC's Avatar
Question Fueling Failure
Hope this is the correct spot to post. if not I apologize
hey there - we replaced the regulator and pump and still get the same issue of a fueling failure.
Yes she does immediately restart. Sometimes with the notice (on an immediate restart). However, if the car is allowed to sit, no issues no warnings.
I was able to detect a VCM Code of 3 * which as I understand it is O2 Sensor. without seeming like a total ninny - if this is part of the catalytic converter on the underside of the car, why is it mounted off the heads at the top of the engine.
VCM does not provide any additional codes after the 3 it simply cycles through the universal symbols of the car (boot, door, bulb etc)
Please help I am at my wits end. ::Sigh::
Old Nov 3, 2013 | 08:46 AM
cjd's Avatar
cjd
What car are we talking about? I am not able to bring up your GIF. Also, I'm not familiar with VCM codes...is that what you are reading off the dash screen?
Your best course is to plug an OBD2 reader into the diagnostic socket under the dash and see what the codes are you get there. If the car is stalling, it will have a code to get you in the right direction.
Old Nov 5, 2013 | 04:00 AM
oldmots's Avatar
See the recent post titled "p1338 DTC Code" for the procedure to diagnose a fueling failure. It should help you.
Old Nov 5, 2013 | 08:18 AM
motorcarman's Avatar
JagGroupLLC
You need to post in the XJ40 section
bob gauff
vsol
Aug 29, 2018 09:46 PM
Pilotman11
Nov 19, 2015 12:55 AM
hoodun
Oct 2, 2015 10:13 PM
mrobinson
Sep 18, 2015 07:20 AM
Tim Goz
Sep 17, 2015 09:11 AM
