High lambda reading
Old Nov 12, 2013 | 12:13 AM
sweeper's Avatar
Default High lambda reading
Took the car for an mot test and the readings for lambda were too high, although the examiner managed to squeeze it through for a pass, all other readings were really good, which suggests an air leak in the exhaust downstream of the lambda sensors. also odd was the readings also showed high lambda on both banks, my thoughts are that the gas analyzer was at fault and not my car, anyone else had any problems with high lambda readings, is there any particular place that the exhausts leak on these models, i can't see or here anything, but I have to say I haven't looked too closely.
The reading was 1.035, co 0.00% and hc 7ppm.
Old Nov 12, 2013 | 02:10 AM
JagV8's Avatar
May not be in the exhaust. Get an OBD tool with live data. Start with LTFT (see my sig) values on each bank, warm engine, parked, at idle and then at 2500rpm. Post them if you want more ideas.
1100me
Jul 24, 2023 06:10 PM
redrover41
23
Sep 25, 2015 01:33 PM
carcycle
Sep 7, 2015 10:22 AM
gregster41
Sep 6, 2015 06:51 PM
gregster41
General Tech Help
Sep 4, 2015 03:51 PM
