Ids software download
Can someone send me a download for the ids v118.5 so I can reprogram my transponder key on my 98-04 Jaguar xj8 and xtype if possible? I have the jlr mongoose j2534 cable, I just need the software to recover and reprogram key 🔑
I hope this does not break any forum rules.
Try to check out this site:https://jlridssdd.com/
Hopefully it will get you to whatever place you're going.
That is a great site that I have not found on my own yet however, my car, and I assume the OP’s, are older than 05 so we are in need of IDS. Not sure if SDD will do what either of us are looking to do. However I found a dealer a few hours away that says they can help me with my issue. Hopefully this will help others and I may still get SDD at some point. Just looking more for the older IDS at the moment. Thanks for the link! Hopefully you don’t get in trouble.
While there is no reliable/trusted information is available for wider consumption, I am under impression that SDD is capable to do everything IDS does as SDD is an advancement from IDS. With limited experience I have with mine set up, I need to change a power supply., I was able to access successfully many different functions.
Normally $3,848.00 now $2,664.00Save 31%
IDS will NOT work with a MONGOOSE type communication device.
Jaguar made SDD125 onward compatible with the generic J2534.
All IDS/SDD software up to SDD124 need a Rotunda VCM.
Early versions of SDD will REVERT to Legacy IDS for certain functions and older cars.
Please read TSB 1-242NAS2 for clarification.
Do you know where I can find SDD v163 and up to work with the generic Mongoose J2534? Previously I used v164 and the Chinese cracked patch, but that is no longer there. I need to read error codes to diagnose a MAF sensor issue but the dealer level software is most informative.
freeb1703
Jul 20, 2024 02:15 PM
mgherghina
Nov 30, 2019 08:06 PM
bookman
Dec 29, 2014 11:03 AM
