As the winter already arrived and the wipers are in deep use, I'd like to ask these following questions:
1. As my car is LHD, (photo #1), does the left/driver side wiper blade, originally, comes with this aerodynamic spoiler, (photo #2)?
2. What about the right/passenger side wiper blade? ain't it also require an aerodynamic spoiler as well, (photo #3)?
3. What is the genuine, most updated, P/Ns, (SKU), for both wipers?
Thanks in advance.
OEM, if you can find - uber expensive.
Blade inserts are tricky at best.
Replace them with Bosch Aerotwin blades.
They are lighter in weight (much lighter assemblies) and will accept the windshield washer hose.
I have the Bosch Aerotwin on my car and use them on every vehicle I need to fit wipers to. You can also fit the jets to both sides of the wiper arm on the Bosch blades so if the jets come off those old wiper blades you could refit them on the bosch blades get a Y piece splitter and some hose and have jets on both sides, am doing this on my car but I am just waiting for the 3mm hose to arrive.
@Clapton7, if your X350 is LHD, the LH wiper blade, which has the aerodynamic aid (if memory serves), carries JLR part number XR850990. The RH wiper blade on a LHD car has part number XR858025.
The blades should be available from a Jaguar main dealer for about 60 quid.
I have Jaguar OEM wiper blades on my 2005 Jaguar XJ8L. Replacing the OEM wiper refills is simple and inexpensive. Just peel away the rubber from the Jaguar OEM wiper refills, and use these refills in their place: Anco N-19R & Anco N-24R wiper refills.
I think part No:AS608??
I've used these OES Genuine Blades from Advance Auto Parts. The washer spray pattern seems a little different from the new washer jet, but it works on both sides.
