Loose outside mirror
Old Nov 5, 2021 | 11:18 AM
Isoruku's Avatar
Default Loose outside mirror
Hi everyone. Today, I discovered the my driver's side mirror housing is a bit loose where it is attached to the front door. It may have come loose due to too many car washes over the years...? But as you can see, the gap is about 5 mm or maybe more. I tried to push it back in after pulling back to rubber just a bit with a screwdriver to see if it would re-seat itself, but no, it's permanently loose. (And the rubber no longer looks smooth, thanks to my trying to pull it back slightly in order to get the mirror housing in again.) My local Jag dealer has a body shop, and maybe that's the way to go, but I'm wondering if perhaps a few drops of Crazy Glue inside the gap while pressing in might solve the problem. Any thoughts? Thanks.
Old Nov 5, 2021 | 11:26 AM
xalty's Avatar
normal. seal is broken so just leave it alone
Old Nov 5, 2021 | 11:41 AM
Isoruku's Avatar
It's not the broken seal that bothers me so much, but rather the fact that the housing for the mirror is pulling away. See the top arrow.
Old Nov 5, 2021 | 11:52 AM
xalty's Avatar
that's normal the seal fills the gap
buy a new one or just deal with it
Old Nov 5, 2021 | 12:26 PM
Isoruku's Avatar
The seal doesn't fill the gap, as shown. Maybe someone else has experience with DIY repair.
Old Nov 5, 2021 | 06:30 PM
meirion1's Avatar
I suspect that you may need to remove the door card and a plastic cover on the inside
of the door then tighten the nuts or bolts that are holding the mirror in position.
Old Nov 6, 2021 | 04:57 PM
Wingrider's Avatar
+1 on removing the door card,,, as meirion1 suggested.
While your there you might want to replace the rubber seal if its available.
stremsjg
Aug 26, 2018 07:08 AM
skubeedoo
Jan 7, 2016 11:52 AM
Ziggy
Jul 16, 2014 05:24 AM
usaftbird
Mar 22, 2012 08:12 PM
monz87
Apr 1, 2010 06:05 AM
