Lower Radiator Air deflector
Old Apr 8, 2020 | 08:13 AM
chewyshaun's Avatar
Default Lower Radiator Air deflector
Hi, I removed my front bumper to replace some parking sensors and this piece of trim basically fell to the floor. Anyone have a clue if this is meant to attach to anything. It appears to sit on top of the front bumper under tray?
Old Apr 8, 2020 | 11:36 AM
Wingrider's Avatar
Slides up under the radiator, it took me a while to figure out just how it went back together.
But much like a weapon, it fits right into place from the right angle.
Lay there for a while with the part, and it should come to you how it goes.
Old Apr 8, 2020 | 12:13 PM
JoeDredd's Avatar
In the pucture above if you look along the edge on the ground you will see rust marks where it clips in place. I bet they have rusted away and it's dropped off or you may be able to see them on the bottom of the radiator. I had to replace mine as it was smashed to pieces.
Old Apr 8, 2020 | 01:56 PM
chewyshaun's Avatar
So just to be clear, does it actually attach to the bottom of the radiator with clips and screws ?
Old Apr 8, 2020 | 05:19 PM
chewyshaun's Avatar
ok I have managed to find pics of how this thing clips to the bottom of the radiator, next question is where do I get these clips?
Old Apr 9, 2020 | 03:25 AM
MCFastybloke's Avatar
Did mine yesterday, 3 clips stayed on the rad and one missing, no screws just the barbed clips , tricky to align all four for the final push.
Old May 29, 2020 | 06:17 PM
brian5's Avatar
I have the same part that fell out when I removed the bumper, been lying on my back for about an hour trying to get it to fit "somewhere", believe it or not, I had it off before, last year when i did the valley hoses, that time I had it up on a 2 poster ramp and I still couldn't figure out how it went on, I just kept chucking it at it till it "seemed" to find it's place. This time, the car is on the deck and I have already refitted the front bumper, etc, maybe I should have fitted this first.
So I will get back under in the next day or so and try try try again.
Old Mar 20, 2021 | 05:13 PM
Mark M's Avatar
Default Help... clips to attach lower radiator air deflector
Help... I need to get the clips that atta h the lower radiator air deflector to the radiator but cannot find them literally anywhere. What are they called, part number? Where can I get them, I have a new radiator air deflector but cannot attach it to 2006 jaguar x350 4.2
swingwing
Jun 17, 2017 01:02 AM
Tango Nevada
May 26, 2017 04:15 PM
MJB1221
Feb 6, 2013 07:57 PM
FireCrow
Sep 16, 2012 07:09 PM
hafferf
Jul 10, 2010 09:01 AM
