misc. code help - B SRS 2293, CEC EVAP Leak, Battery Flight Data ASC Fail
Old Oct 7, 2020 | 11:08 AM
RoadMaster2's Avatar
Default misc. code help - B SRS 2293, CEC EVAP Leak, Battery Flight Data ASC Fail
Well why not get everything on the table!
I had a check engine light on for a bit and the airbag warning light comes on intermittently, but is mostly on.
The codes shown were -
1. B SRS - 2293 clock spring airbag fault.
2. CEC EVAP Leak - fuel cap 15 purge
3. Battery - Flight Data - Jag ST ASC fail.
My shop says these are dealer fixes.
That's fine - I just looking for background so I understand these better when talking to dealer.
Thanks.
Old Oct 7, 2020 | 07:33 PM
meirion1's Avatar
No direct experience of these codes but:
If it's a bad connection on the clock spring then that is cleanable.
I believe that the fuel tank is under vacuum or maybe just sealed-check cap for sealing
no 3 ????
Avoid a dealer if you possibly can.
Old Oct 7, 2020 | 07:47 PM
Wingrider's Avatar
Clock spring replacement isn't that bad a job, but the cost of the part is pricey enough.
Try to avoid the dealers service dept, if you value your cash.
Befriend yourself to the parts people, & acquire yourself a discount.
Akwarr
Dec 6, 2018 05:35 PM
HaydenS
Aug 23, 2017 12:05 PM
zidjan
Aug 16, 2017 06:05 PM
reddawn
Oct 15, 2012 12:53 PM
s1var7
Oct 1, 2009 02:29 PM
