Noise in front end
Old Oct 1, 2016 | 08:50 AM
viper1996's Avatar
Default Noise in front end
Wheel bearing type noise...Kind of whirring noise, not real loud but noticeable...But only under acceleration...When I let my foot off the gas the noise disappears...Thanks!
Old Oct 1, 2016 | 11:26 AM
Don B's Avatar
Hi viper1996,
What year and model?
Don
Old Oct 1, 2016 | 02:13 PM
viper1996's Avatar
04 XJR...
Old Oct 1, 2016 | 08:57 PM
Don B's Avatar
Do you hear the noise only when moving, or does it occur if you rev the engine with the transmission in Park?
If you can hear it in Park, you may be able to track it down with an inexpensive mechanic's stethoscope or a long screwdriver or socket extension used like a stethoscope.
Could it be supercharger bearings? A belt idler pulley?
Cheers,
Don
Old Oct 2, 2016 | 08:31 PM
viper1996's Avatar
Thanks, It is definitely in the drivetrain...
Old Oct 2, 2016 | 11:18 PM
Don B's Avatar
Have you checked the wheel bearings?
If the bearings seem okay, could a failed engine mount be allowing excessive engine movement such that a rotating belt-driven pulley is coming into contact with something it shouldn't?
Have you scanned the system for stored diagnostic trouble codes that might indicate an air leak as the source of your noise?
You're not giving us much to go on.
Cheers,
Don
Old Oct 3, 2016 | 04:45 AM
Mirsteve's Avatar
Well, it is a common thing. Firstly, look behind the guard, towards the front of the motor where the ventilation system jolts onto the motor. You'll take note of that they have tin covers on them, one on every complex. One of both are likely kinda free and reverberate with motor pace. Purchase some substantial band clamps and wrap them deliberately around the culpable heat shield.
Old Oct 3, 2016 | 03:04 PM
viper1996's Avatar
I will elaborate more...Noise is only under acceleration which clears out tires, bearings, etc...Not an engine/tranny related noise...My thoughts are is there anything in the drive shaft area that may cause it...When you let off the gas it totally goes away!
Old Oct 3, 2016 | 03:19 PM
philwarner's Avatar
Supercharger?
Old Oct 3, 2016 | 06:02 PM
Don B's Avatar
MMy thoughts are is there anything in the drive shaft area that may cause it...When you let off the gas it totally goes away!
The rear engine mount/transmission mount is there. Also the heat shields riveted to the body near the exhaust downpipes can pull loose and come into contact with the exhaust when the engine leans under acceleration.
Old Oct 4, 2016 | 08:58 AM
philwarner's Avatar
Perhaps check the engine mounts by watching how far the engine rises if you rev it in drive with a foot firmly on the brakes. Try reverse too. Both of mine were separated and although the right side did not show it by engine movement, the left side let it rise up to the limit of the little safety strap.
Old Oct 4, 2016 | 09:12 AM
viper1996's Avatar
Its hard to explain but I can tell its a rotational noise like a what you hear when a wheel bearing is bad...Thanks for responses!
Gerry1
Jul 25, 2022 05:56 AM
lc3566
Jul 16, 2017 07:43 AM
LnrB
Sep 11, 2016 07:40 AM
Drcummins
Sep 9, 2016 09:36 PM
MichaelJohn
Sep 7, 2016 07:19 PM
