O2 sensors reading, is this normal?
Old Mar 26, 2022 | 05:27 PM
  #41
Aarcuda's Avatar
Originally Posted by XJR_hunter
Here are my results. I reckon those O2 sensors are screwed. Genuine replacements ordered. Previous owner has fitted eBay ones that cost 23 quid :/
ya those are dead. Lets see if new o2 sensors fix it.
Old Mar 26, 2022 | 05:30 PM
  #42
Aarcuda's Avatar
In sdd try and narrow down the range on the live data to get better resolution. For instance if the plot shows a straight line at 15 mA set your limits on that line to be minimum 14 maximum 18 and then look at the graph and then you’ll be able to see if there’s any up-and-down movements
Old Mar 26, 2022 | 05:35 PM
  #43
Aarcuda's Avatar
Also in SDD for the first sensor you want to look at the current and on the second sensor you wanna look at the voltage. So when you set up the live monitoring pick oxygen sensor bank one sensor one and bank two sensor one look at the current and for bank one sensor two and bank two sensor two, look at voltage’s
Old Mar 26, 2022 | 06:02 PM
  #44
XJR_hunter's Avatar
It won't let me upload it here, but that is a screenshot of a video in which the car idles then revs up to 2500RPM and then falls back to idle.
When it falls back to idle the current on the upstream sensors goes up to 9.7A. That's right, 9.7 Amps, not milliamps. See below:
P.S I've also ordered a replacement MAF sensor. Might as well do everything.
Old Sep 28, 2023 | 07:50 AM
  #45
GreenV8's Avatar
Having absolutely the same story, did you find out the problem ?
JacksonvilleJag
F-Pace (X761) / C-X17
Mar 7, 2022 12:37 PM
Amphicar770
Oct 26, 2017 09:00 PM
adam699
Sep 24, 2011 07:11 PM
XJR96
Jun 18, 2011 02:00 PM
argatoga
Feb 3, 2010 12:53 PM
