P2601 and RP
Old Dec 5, 2012 | 10:45 PM
kj217's Avatar
Default P2601 and RP
my 05 XJR just went into Restricted Performance mode and threw P2601,, no CEL,,
i pulled over and restarted the engine and RP was gone,,
please,, help,,
Old Dec 6, 2012 | 01:59 PM
kj217's Avatar
my indy checked the SC water pump and found it operating,,
any other possible reason to have the P2601?
Old Dec 8, 2012 | 07:33 AM
kj217's Avatar
anyone installed a johnson cm30 i/c pump on X350 R?
Old Dec 9, 2012 | 12:34 AM
kj217's Avatar
anyone?
Old Dec 9, 2012 | 02:59 AM
u102768's Avatar
P2601 is listed as being for the Auxiliary Coolant Pump. Isn't that the one for the Climate Control, not the S/C?
Old Dec 9, 2012 | 03:14 AM
kj217's Avatar
i don't see why it goes into RP due to heater pump,, heater would simply not work,, so i believe its the SC coolant pump,, i also experience engine rattle and pinging in acceleration,,
car also throws P1646,, and yet no CEL,,
Old Dec 9, 2012 | 02:04 PM
u102768's Avatar
I thought it odd that a problem with the Auxiliary pump would cause RP as well but, unless there is an error in the workshop manual, there is a different code for a S/C coolant pump malfunction. Maybe it is a red-herring?
Old Dec 9, 2012 | 02:36 PM
kj217's Avatar
i/c coolant pump code found in manual P1474 and said to kick amber light,,
now am consused,,
Old Dec 11, 2012 | 02:13 AM
kj217's Avatar
i checked the i/c coolant pump and found it not working,, i have an extra DENSO MNA6710AB which is the heater auxiliary pump,, would this pump fit and compensate?
Old Mar 3, 2016 | 03:01 PM
joebit's Avatar
Hi there
I got the same 2601 SC coolant error and my engine has pinging going on as well. How did you go rectifying these problems. Also any news about the Johnson CM30 SC pump
regards
Joe
Old Mar 4, 2016 | 10:54 AM
JagV8's Avatar
Wow - thread resurrection!!
Change the SC pump / check all its wiring.
Search if you want more info but it may take real effort as this issue is rare.
Old May 26, 2016 | 06:33 AM
joebit's Avatar
Changed the sc coolant pump with a second hand one and the RP error still present but not all the time.
Any ideas?? Please??
Old May 27, 2016 | 02:17 AM
JagV8's Avatar
Just about could be the IAT2 but do you definitely have coolant flow? Changed pump does not guarantee that...
2010 Kyanite XFR
Apr 30, 2015 07:54 PM
qasimak
Sep 27, 2014 04:45 PM
2010 Kyanite XFR
Jul 2, 2014 08:07 PM
raschwar
Oct 5, 2013 05:38 PM
ooootis
Jun 4, 2012 04:12 PM
