Passenger Side headlight XJR
Old Jan 30, 2015 | 04:38 PM
jagman2004's Avatar
Default Passenger Side headlight XJR
Trying to replace HID headlight on 2004 XJR. There is a removable plastic cover on the backside inside the engine compartment. I need to remove that cover to gain access. I can remove it on the driver side but am having no luck on the passenger side. I can unlatch the cover and move the top back but I can't get the cover out so I can get to the bulb -- I can get the cover off on the driver side.
Any suggestions?
Ben
Old Jan 30, 2015 | 04:56 PM
jackra_1's Avatar
I just did this on my 2005 XJR.
I had to put a lever tool down between the cover and the main housing at the bottom and twist to widen the gap at the bottom and then pull towards the engine compartment. The grounding wires at the back dont help as they take up space. With some force I was able to get the cover off without damage.
Old Jan 30, 2015 | 04:57 PM
Cambo's Avatar
Welcome to the forum jagman, nice to have you with us.
When you get a moment, stop by our new members area and introduce yourself ==>> New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
In order to get the bulb out, I think you'll find that the front bumper needs to come off, and then you remove the complete headlight assembly.
Old Jan 30, 2015 | 05:11 PM
gatekeeper's Avatar
If it's too tight a fit for your hands, or the cover, you may need to remove the front bumper cover and either loosen or remove the headlamp to gain access and replace the bulb.
Old Jan 30, 2015 | 05:20 PM
jackra_1's Avatar
One point I forgot is that the more you lever the top of the rear cover back the more the bottom "digs in". So when you try to pull it towards the engine compartment try and have the top part as far forwards as the lever tool allows.
I certainly was not about to take the front bumper off when it really is not necessary so long as you do not have very large hands!
Old Feb 1, 2015 | 09:16 AM
jagman2004's Avatar
Thanks much to all -- I'll see what I can do.
Old Feb 1, 2015 | 11:46 AM
jackra_1's Avatar
Default Change to instructions
My instructions above are incorrect. I should have said the opposite in that the top of the rear cover should go back as far as possible towards the back of the engine compartment. There is a wire loop at the bottom of the headlight body that holds a protrusion at the bottom of the cover.
Old Feb 1, 2015 | 07:15 PM
gmcgann's Avatar
Here is a write up from when I replaced mine. It was pretty simple to remove the whole headlight. https://www.jaguarforums.com/forum/x...acement-70056/
99xk8guy
May 28, 2024 09:36 PM
Dicque
Sep 19, 2015 12:53 PM
Bowman
Sep 15, 2015 06:54 AM
sklimii
Sep 5, 2015 06:04 AM
laserguy
Sep 3, 2015 02:02 PM
