Pending rpm
Old Mar 9, 2018 | 12:22 PM
Micke Hall's Avatar
Default Pending rpm
Xj8 2003 with pending rpm between 200 rpm it shows in rpm meter and i can feel it when i drive 1100 to 1200 rpm. What can it be?
Old Mar 9, 2018 | 01:02 PM
JagV8's Avatar
What is "pending rpm"?
Old Mar 9, 2018 | 01:41 PM
Micke Hall's Avatar
i am not so God in English....engine speed is pending by it self in 1100 to 1200 rpm when i drive
Old Mar 9, 2018 | 02:29 PM
woox4's Avatar
Do you mean the RPM is hunting (jakt)?
Old Mar 9, 2018 | 02:38 PM
Micke Hall's Avatar
When i drive in 60km speed the engine rpm is not stable it is pending betwen 1100 to 1200 by it self
Old Mar 9, 2018 | 04:55 PM
JagV8's Avatar
OK... Varying.
Might be the torque converter.
You could watch the fuel trims in case they give any clue.
Old Mar 9, 2018 | 11:23 PM
Don B's Avatar
Hello Micke,
Welcome to the Jaguar Forums! It's great to have you with us.
A number of issues can cause the engine rpm to be unstable. My first suggestion would be to have the car scanned for any stored diagnostic trouble codes or "fault codes." The computers may have stored codes that will help diagnose the cause of your variation in rpm.
If any codes are stored, please post them here exactly as they appear with the letter and four numbers (for example, P0171, P0743) and we will try to help.
Cheers,
Don
Old Mar 10, 2018 | 02:40 PM
Fraser Mitchell's Avatar
Does this "hunting" up/down disappear after the car has done a few miles (like 4-5) ?
If it does, it is the same as I had over my ownership of my first X350, and I drove the car from 30k to 115k and the syndrome was there when I part-exed it for an X358 that doesn't have it. I was told it was a "clever wheeze" by some engineer to cycle the torque converter lock-up clutch to create a bit of friction to warm up the transmission fluid quicker. I just used to put the transmission in 5 or even 4 for a bit.
zephyrprime
65
Aug 29, 2016 06:21 PM
mick99
Jan 7, 2013 02:22 PM
stonehenge kid
Jul 20, 2011 04:22 PM
mbenvo
Apr 23, 2011 01:56 PM
JonPham
Nov 2, 2009 09:14 AM
