REM Module throwing errors?
I have a 2004 XJ8 VDP, and recently had a new headliner fitted. I noticed after about 2 weeks the sunroof did not open and close properly and so I ran my Foxwell scanner through the system and on "Module 11, REM" as seen in the attachments were all RED.
My concern is that its showing the sliding roof switches "Short circuit to ground"and I was wondering if this condition would run my battery down?
Last week I did put in a new battery since the old one was from March 2011 and was not holding its charge, obviously I do not want to damage the new battery!
Another concern is it is showing problems with the fuel pump...the car starts and runs good?
It shows problems with the rear light which does not exist...all lights work OK?
Is it possible that the REM Module itself is faulty and giving off sperious signals?
Any help would be greatly appreciated, David
+1 to listen opinions and share experience re fuel pumps control out of range/non working when requested. I have same errors since I bought the car. I changed all pumps as I got error with secondary pump in addition.. nothing changed as well as car starts and running good. However error with secondary pump disappeared.
djpxk8 (03-01-2018)
Unlikely shorts to ground
With so many of these errors I would expect there is probably a bad ground in your system. The bad ground causes a large voltage drop across that connection. The comm errors also appear when the voltage drops below a certain level and is also affected by bad grounds - comm errors can occur with the voltage as high as 12.2v. Both my GEM and REM drop out around that voltage.
That would be a good place to start. Don't forget both battery posts as well - they may look OK but clean them anyway. Then the two -ve connections to the body, on the battery -ve cable.
Then check everything that is operated by the SCP bus to see if there is a break somewhere in that circuit. The roof is controlled by that as well as many others. There is a test somewhere in Jags manuals that indicates that if you can do universal open and close from the fob, and everything works, the SCP network is completely functional. Been a while since I read that but I think that is what is said.
paydase (01-13-2021)
Originally Posted by Hendirk View Post
I did clear all the codes (multiple times) after the headliner removal but the codes keep coming back.
The system reset is done by connecting both battery cables for some seconds right? If so, then I did that as well
Believe that you will need a Jaguar type of reader to clear the codes.
But i could be wrong
