Separating Lower Intake From Upper?
Old Nov 8, 2025 | 05:12 PM
Mac Allan's Avatar
Default Separating Lower Intake From Upper?
Two quick questions:
1. Can you confirm that this is done once the intake manifold is out of the car, manifold turned upside down and loosening the small T20 torx screws?
2. After replacing the eight seals/gaskets what is the correct torque for the T20 torx screws? I can't find anything in the Factory Workshop Manual regarding this or replacing the seals.
Thanks!
Old Nov 9, 2025 | 12:31 AM
Wingrider's Avatar
They are small fasteners not much force to remove.
Just used about the same torque as to open.
The manifold is plastic so good & snug will work.
laurelez
Oct 12, 2024 09:57 AM
Kennyk
Nov 20, 2021 06:51 PM
Kennyk
Nov 17, 2021 07:41 PM
seanshamrock0000
Mar 12, 2011 06:57 PM
stevis05
Feb 17, 2009 05:30 PM
