Supercharger Empty!
Old May 30, 2024 | 12:13 PM
04Xjrsteve's Avatar
Default Supercharger Empty!
Unplugged the supercharger reservoir & nothing came out but the stink! Have they been known to go dry? Certainly no indication of a leak anywhere.
Thanks and best,
Steve S.
Old May 30, 2024 | 12:50 PM
clubairth1's Avatar
Community Influencer
Oil or coolant dry??
Old May 30, 2024 | 01:01 PM
04Xjrsteve's Avatar
Thanks, Clubairth.
I have the SC & Intercoolers, etc. off the car. It is the oil reservoir that is empty..
Old May 30, 2024 | 06:57 PM
04Xjrsteve's Avatar
Default Sorry, Not True!
Found the oil! Forgive the confusion!
Old May 31, 2024 | 07:37 AM
Panelhead's Avatar
Default Good news
The supercharger would not work long with oil or water, maybe a few miles.
Old May 31, 2024 | 08:03 AM
04Xjrsteve's Avatar
Almost feel ridiculous explaining:
Have SC off the car. Removed oil plug & turned upside down & only a smidgen came out. However, after arranging sc & walking away for a few hours, a reasonable amount of oil came out. Will measure amount & turn her various ways to be sure.
Old May 31, 2024 | 12:00 PM
JoeDredd's Avatar
There isn't a huge ammount in it about 120ml if I remember right, I think thats 7 and 3/4 of a furlong in strange American units.
Old May 31, 2024 | 12:36 PM
clubairth1's Avatar
Hey glad to hear there was oil!!
Thanks for reporting back as the M112 is not known as a leaker but anything can leak.
Old May 31, 2024 | 02:19 PM
04Xjrsteve's Avatar
Speaking of SC oil, would there be any value to pouring a little solvent in after the oil is out to wash the residue out?
Thanks and best,
Steve S.
Old May 31, 2024 | 04:20 PM
Pete M's Avatar
Hi Steve,
The usual way of changing the supercharger oil is to put a long thin tube onto a syringe and suck it out. Refilling it is done the same way. Note that the quantity is set, and it is not just filled until it leaks out the filler port.
Pete M
Old May 31, 2024 | 04:25 PM
scottjh9's Avatar
I would not use solvent with the rotor pack inside. The black coating will start to come off. You can remove the snout then rotor pack and clean the housing. There are needle bearings in the rear to be careful of too. Resealing everything is easy using a loctite sealer on the flanges
Old Jun 2, 2024 | 06:50 PM
Jaroslav Záruba's Avatar
this has to be the funniest post I've read around here 😁😂😂😂
Old Jun 2, 2024 | 10:23 PM
04Xjrsteve's Avatar
Default Satay Tuned, Jaroslav
You ain't seen nothin yet!!
robroy
Dec 10, 2021 09:24 AM
asjdhsajhdfj
Jun 4, 2021 09:39 AM
Big E
XJ40 ( XJ81 )
Mar 2, 2014 01:03 PM
roger ele969c
XJ40 ( XJ81 )
Jun 10, 2011 05:52 PM
jimmycruz99xjr
Feb 1, 2011 11:01 AM
