TCM - ECM software x350
Old May 6, 2024 | 12:06 PM
MBolo's Avatar
Default TCM - ECM software x350
Hello.
What is the latest software for the Jag x350 j8 TCM and ECM modules today? Or where can I find them?
I will be grateful for your help
Old May 6, 2024 | 07:51 PM
abonano's Avatar
Originally Posted by MBolo
Hello.
2012 I believe and only resides with Jaguar software. IDS or SDD.
No other option. You need to find someone with the above.
Good luck
Old May 7, 2024 | 01:50 AM
MBolo's Avatar
Default FLASH
I mean flash. What is the newest one and where can I find it? I have updates in the Jag from 2003, TCM and ECU from 2005
Old May 7, 2024 | 07:02 AM
abonano's Avatar
Again, 2012 is the latest flash programming for the 2003 - 2008 X350 and you need Jaguar propetaritary system (IDS/SDD) to access these flashes.
Old May 7, 2024 | 08:33 AM
MBolo's Avatar
I have a JLR SDD. Unfortunately, when I program ECM and TCM, it inserts flash from 2003.
Old May 7, 2024 | 08:36 AM
JagV8's Avatar
So what date & version is your SDD?
Sounds like too early.
Old May 7, 2024 | 08:40 AM
MBolo's Avatar
I am sending files with ECM and TCm data. Now I have version 164
File Type: pdf
File Type: pdf
File Type: pdf
Old May 11, 2024 | 01:32 AM
MBolo's Avatar
Does anyone really know how to upload the latest flash to cat and where to find it?
Old May 11, 2024 | 02:06 PM
MBolo's Avatar
Is there really no one who can help me with the problem of how to find and insert the latest flash via JLR SDD 164 into the ECU
Old May 11, 2024 | 04:13 PM
Thermite's Avatar
Might do yourself a benefit by reading all the posts you have made to the forum, so far?
"Wisdom" thing, when it comes to pushing the limits of a used motorcar already 19 model-years in road-wearying service. Check both gloveboxes. My bet is the OEM issue of "get stupid and nail it" pills was used-up long ago.
Based in Poland, think Germany has no speed limits?
New news to the long-suffering Germans, for dam' sure!
https://www.schumachercargo.com/auto...e-travel-tips/
Note an as-built Jaguar can easily double the recommended limits, right out of the box.
And "the wishful" wonder why the Germans consider ill-mannered auslander's heathen barbarians on their roads?
Those who can best assist might have become motivated to give it a miss, watch from a distance, and go off for an overdue ****, instead?
"Just sayin'"
Old May 11, 2024 | 04:54 PM
xalty's Avatar
there are at least 6 or 7 tcm hardware variations for 03-05 cars and the calibration is assigned automatically. some haven’t been updated in a long time
Old May 12, 2024 | 02:54 PM
abonano's Avatar
You need to update to either 118.5 IDS or 130 SDD - that is where you will find the last flashes procured in 2012.
Old May 13, 2024 | 10:36 AM
MBolo's Avatar
I have SDD v164. Unfortunately, it does not update the flash ECU, the connector still has the same version. Maybe I'm doing something wrong. Can anyone tell me how it should be done correctly via SDD.
File Type: pdf
RitcheyAuto
Feb 22, 2017 06:24 AM
kbeachy
29
Mar 2, 2015 06:21 AM
MRomanik
Sep 12, 2009 10:33 PM
97xkay8
May 8, 2008 09:07 PM
