Temperature going to Red
Old Jul 1, 2019 | 09:13 AM
Faz's Avatar
Faz
Default Temperature going to Red
Hi all, have a problem with Jaguar XJ X350 over heating..... this seems to follow the air con blowing hot air, then temp gauge rockets up..... has anyone had this problem or knows a solution??
Faz
Old Jul 1, 2019 | 09:19 AM
jackra_1's Avatar
Lots of threads on this and lots of possibilities including a problem with the thermostat, fans, blockage in cooling system, leak, even leaves/debris in between radiators. Also wrong coolant being used.
Do not drive with the idiot gauge showing temp in red as the engine probably was in danger before the idiot gauge was in the red.
Old Jul 1, 2019 | 09:22 AM
Faz's Avatar
Faz
Thanks Jackra... looks like a few possibilities and £'s spent to get to the bottom of...I'll try the thermostat first.
Faz
Old Jul 1, 2019 | 09:24 AM
jackra_1's Avatar
An infra red gun could see what the temperature is either side of the thermostat with engine running to see whether it is opening properly.
Old Jul 1, 2019 | 11:51 AM
jazzyjags's Avatar
Start with the inexpensive troubleshooting/repairs. Do you have enough coolant in your system (no "Engine Coolant Low" warning)? If so, try bleeding any air out and refilling. I had air in my coolant system after a few project and it caused the temp gauge to shoot up pretty quickly
Do you have any ongoing leaks? Like John mentioned, thermostat is also a good starting point. Keep us updated.
Old Jul 1, 2019 | 01:57 PM
Fraser Mitchell's Avatar
Faz
Have you checked the coolant level ?
Old Jul 1, 2019 | 04:01 PM
XJ8JR's Avatar
First confirm that the radiator fan is working.
Old Jul 3, 2019 | 07:24 AM
JX350's Avatar
Hi Faz, And check the thermostat housing is not cracked or leaking. The thermostat housing also contains the thermostat and coolant temp sensor so worth checking the condition. If the housing is very old then it's worth just changing it as a precaution and the housing in the UK is pretty cheap at the moment from a couple of jaguar parts suppliers. I just changed mine and it's not that bad to change. I bought the housing which comes with the thermostat and coolant temp sensor included.
thegreenjaguar
Sep 20, 2024 11:37 AM
Sober Driver
Sep 21, 2018 09:58 AM
sailor
XK120 XK140 XK150
May 9, 2015 01:47 PM
DuhCar
Dec 29, 2014 11:33 AM
Innovative Detailing
Detailing / Car care
Feb 5, 2010 12:09 PM
