are these auto trans the same?
Old May 18, 2021 | 07:09 AM
the brain's Avatar
Default are these auto trans the same?
Hello
Would an automatic box from 2002 xj8 3.2 be the same as 2004 xj8 3.6
I want to swap the older one into my 2004 as trans is playing up
thanks
Old May 18, 2021 | 09:02 AM
wfooshee's Avatar
They're different transmissions. The 2002 is a 5-speed, the 2004 is a 6-speed. Controller electronics will be completely different.
Old May 26, 2021 | 08:47 PM
Don B's Avatar
I have had good success restoring the 6-speed ZF transmissions to proper operation by changing the pan/filter and connector sleeve, flushing the fluid, then using SDD to clear the adaptations and update the firmware to the latest version (2006).
Short of that, you should at the very least inspect for fluid leaks at the pan gasket, because low fluid will cause slipping. Also inspect for fluid in the electrical connector, which can cause various other malfunctions.
Cheers,
Don
MRomanik
Non-Jaguar Vehicles
Mar 28, 2015 12:18 AM
2jag
Jan 22, 2013 11:21 AM
belsy
May 28, 2011 01:48 PM
XJ ate
Oct 4, 2009 02:22 PM
jensenguy
Aug 14, 2009 12:43 PM
