throttle aftermarket controller
Old Aug 27, 2018 | 12:41 PM
WHY ME?'s Avatar
Banned
Default throttle aftermarket controller
Acceleration hesitation from a stop.It acts like it only wants to go when it gets around to it. Ifind myself feathering gas pedal to get it to take off. what is wrong?
How to repair. Was told its a fly by wire car, an i need electronic aftermarket controller. Is that true?
Old Aug 27, 2018 | 01:03 PM
I've moved your post from the XK8?r section to the Model specific XJ (X350/X358) section where members with like models can better assist you.
Old Aug 27, 2018 | 01:22 PM
JagV8's Avatar
True.
No.
Probably something like an air leak or blocked fuel filter or failing fuel pump or ...
If you're not going to DIY find a competent tech!
Old Aug 27, 2018 | 02:09 PM
Brutal's Avatar
Hmmm air leak just reminded me of what happen with a broken drivers engine mount. Lets the air intake tube from the throttlebody pull loose and when you give it so much gas the engine jumps up it falls on its face till engine and tube come back together. Hense the "feathering the throttle to go" how i know i have broken my engine mounts again. I keep telling myself to cable the engine down like on my race car. And since youre a tech you know to give the car gas in drive with foot on the brake and hood open to see if the mounts are indeed broken by how much the engine jumps up. I know your old now cause you forgot that shyt.
JimC64
Sep 22, 2025 02:52 PM
Don B
General Tech Help
17
Aug 8, 2017 09:11 AM
Spikepaga
Oct 3, 2016 03:30 PM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
sjuraud
Aug 28, 2010 02:11 PM
