Trans problems!
Old Dec 28, 2017 | 12:46 AM
BlackKat's Avatar
Rent a brake kit to add a flange to your pipes and use 2 claps per end than just one. This will prevent the hoses from popping off. Also verify that the hoses are hydraulic grade. NAPA sells heavy duty hydraulic grade hoses by the foot for cheap. I did exactly this rather than buying a new oem set singe these still have problems.
Old Dec 28, 2017 | 09:22 PM
annamiata's Avatar
Correct me if I am wrong, it appeared that the spilled oil has a red tint similar to Ford oil. I am guessing that the previous owner purposely cut the line to flush the system to replace with Ford oil once already.
Old Dec 28, 2017 | 09:52 PM
abonano's Avatar
Possibly but more than likely the original fitting was weeping. This is a known fix, opposed to replacing the line
Old Dec 29, 2017 | 04:42 PM
Jakepatch's Avatar
Update: Got the line put together, Mercon fluid added, and drove it the 500 miles home with out any issues. Thanks again to everyone for the helpful hints. Now that I am home and in my own garage i plan to replace the lines correctly, and probably do a tranny filter/flush while I'm at it just to make sure everything is good.
Old Dec 29, 2017 | 05:13 PM
Box's Avatar
Box
For a proper repair, use a double flaring tool to create a barb on the 1/2" aluminum line ends, and then get 1/2" ID transmission hose from your local NAPA store and use fuel injection clamps like this.
Old Dec 29, 2017 | 05:24 PM
Fraser Mitchell's Avatar
And a heart-felt well done for getting out of this unwanted problem !!
milleniumaire
Oct 1, 2020 05:59 PM
Gregfromuk
Oct 7, 2013 03:03 PM
JaguarXKR
Aug 8, 2013 11:38 AM
WhiskyTangoFoxtrot
Jun 16, 2011 08:48 AM
jonre
Apr 30, 2010 03:16 PM
