Transmission error light
Old Jan 7, 2021 | 12:42 PM
Sodingile's Avatar
Default Transmission error light
Hi everyone. Please help. i have an orange transmission light on and the jag wont start. i think the transmission fluid is overfilled by half a pint or so. Could this be the reason? I tried moving the gear to neutral. The car can roll but still wont start. I tried to diagnose but it only says transmission error. It was driving fine and I Parked it for three days and now this. Its not the battery because the battery is new. Please help. Thanks
Old Jan 7, 2021 | 01:01 PM
NBCat's Avatar
Battery age is immaterial. What is the voltage across the battery terminals with the ignition in the OFF position when checked with a voltmeter? If the voltage is less than 12.6 volts, charge the battery for five hours at 2 to 5 amps and retest it again with the voltmeter.
Old Jan 7, 2021 | 01:07 PM
Sodingile's Avatar
Many thanks. Will look into that
Old Jan 12, 2021 | 08:29 AM
Sodingile's Avatar
Hi
I am sorry am not here often these days. I work for disaster management so we have our hands full during this lockdown phase.
I had the battery charged for over 5 hours and still no luck. The orange transmission light is still on. Now am getting worried, I hope its not serious. Any help will be appreciated.
Old Jan 12, 2021 | 08:43 AM
jackra_1's Avatar
Get the fault codes read.
Old Jan 12, 2021 | 09:37 AM
Sodingile's Avatar
Thanks John
I have P1791 Transmission Control Module
1315 misfire excess emissions and
1621
Any ideas of what am facing?
Old Jan 12, 2021 | 09:51 AM
jackra_1's Avatar
https://www.jaguarforums.com/forum/x...driving-51970/
Have a look at post #3 in the above to start.
Others with more knowledge will chime in I am sure.
1621 not listed above however
P1621 Possible Causes
What does this mean?
  • Faulty Powertrain Control Modules (PCM)
  • Low car battery voltage
Old Feb 8, 2021 | 02:18 PM
Sodingile's Avatar
Hi Members
Many thanks for all the help. I charged the battery overnight and the car started. Something drained the battery because I had parked it for more than a week. Battery centre checked it in the vehicle and the alternator was given a thumbs up. They advised that I must use the vehicle often. I will still look into the faults again. Am glad I joined this forum
Old Feb 8, 2021 | 03:05 PM
jackra_1's Avatar
If you leave the car parked for longish periods use a ctek or equivalent battery maintainer.
Old Feb 9, 2021 | 05:04 AM
Sodingile's Avatar
Will do. Many thanks
mh.anthony6
Aug 17, 2020 07:29 PM
euphonium01
Jun 2, 2018 01:42 PM
antuk
May 1, 2017 07:50 PM
Colonel's Jag
Sep 7, 2016 11:31 PM
boonchie
Apr 27, 2008 08:11 AM
