Trunk will not fully close
Old Dec 21, 2013 | 03:08 AM
kehollins's Avatar
Default Trunk will not fully close
The trunk stopped working out of the blue on my 2004 vandenplas. Keyless trunk release doesnt work, button inside vehicle driver side does not open it either. The green Jaguar button on the trunk doesnt open it. However, the key in the hidden key hole does. What fuse is applicable to the trunk closer?
Old Dec 23, 2013 | 02:04 PM
Na5h's Avatar
You may want to look at the posting by "Lagonia': X350 Trunk Latch Actuator - Bench Test? dated 12/17; may provide some answers to your problem. This is exactly the problem I had too.
Old Jul 7, 2023 | 04:46 PM
Clovis997's Avatar
Smile Nice Color!
What type of wheels are those? Thanks
Jagamosis
Old Jul 9, 2023 | 06:32 AM
JoeDredd's Avatar
I bet the self close doesn't work either and you have to slam it hard to close the trunk, if so then a new latch mechanism is the only way around this as the unit is sealed.
Old Jul 10, 2023 | 05:28 PM
meirion1's Avatar
Trunk/boot actuators have a limited life and are not easy to repair.
Old Jul 10, 2023 | 07:19 PM
Wingrider's Avatar
New ones require programing, or a simple replacement?
Old Jul 10, 2023 | 07:41 PM
Terrific's Avatar
No programing. L bought a used one Ebay several years ago, still working fine. Although my problem was not opening.
Old Jul 11, 2023 | 11:15 AM
JoeDredd's Avatar
It's usually the nylon gears that strip but there is a massive rivet holding it all together so actually getting that far is a PITA. Then there are no parts to fix it so bin fodder it is.
Aldo M Martinez
Apr 6, 2020 06:20 PM
wmlaven
Mar 4, 2020 10:29 AM
kksgirl
Oct 4, 2011 06:57 AM
cadrad
Dec 23, 2009 03:16 PM
6pac
Sep 20, 2008 06:43 PM
