Water leaking from the side of mirror to cabin when car wash...RESOLVED
hi! all, i just bought a 2005 XJ8L with 71000 miles on it. many issues on it..
one of the issues is the water will leaking from outside to the inside of the side of front mirror (left & center & right) ... raining inside the cabin when car wash...
it's really a fantastic experience since this is my first jaguar ... -_-!!
does anybody knows how to solve it? thank you. Alex
1. left hand side of the windshield pillar trim (from center to bottom)
2. right hand side of the windshield pillar trim (from center to bottom)
3. control panel of sunroof
so... may i know if you have any idea for what happened? Thank you.
That sounds more like the front drain tubes from the sunroof are leaking into your headliner/pillars. There is a drain tube in each corner of the windshield pan that runs down the corners of the vehicle. Could be that all of your drain lines are clogged and it's overflowing up front.
Yup, I would say front drain tubes clogged with leaves and crud. Very simple to rectify. Happened to me the first time i took it through a car wash.
You'll need to remove the cabin air filter and get your hands in there (passenger side under bonnet and window cover). On the driver side it's under the plastic cover where the brake fluid is held, and under the window cover.
Hi Trosty,
I agree that it's a good idea to clean those drains below the windshield cowl, but just so we don't confuse Alex, from his description of water spilling from his sunroof control panel, I think Sean is correct that Alex's most immediate problem is clogged sunroof drains, the openings of which are in the corners of the sunroof frame in the roof.
Alex's sunroof seal must also be leaking. On our car the seal only leaks when subjected to the high water pressure in a car wash - it doesn't seem to leak in normal rain.
Cheers,
Don
Hi! All, thank you very much. I already cleaned the hole under the windshield and also the holes near by the sunroof tonight. it's really dirty... full of leaves and soils.. will try to clean it again ON tomorrow and also make a test to see if the water will still go inside the cabin.. if yes..then i will go to an independent shop for repairing, if not then i am good AND THANK YOU ALL!!!
after clean up all the dirts and leaves mentioned in above. no water leaking anymore. thanks guys!
__________________
'05 Jaguar XJ8L 71k miles
'13 Lexus CT200H 22k miles
'08 BMW Alpina B7 40K miles
__________________
Mark's idea of weed whacker line is really the best way to go. 12 or 14 gauge Electrical wire also works but fold the end over and crimp, then melt the plastic over the end as you don't want a sharp end. I'm referring to single strand used in home wiring, not braided.
The drain lines are thin flexible plastic. You've probably seen clear rolls of tubing in hardware stores. You can poke through them if you use something too stiff (think the sharp end of a metal coat hanger)
The tubes slide over the metal holes leaving the sunroof in each corner and are held on by clips.
Too much force can slide them off if you use too much force.
For this reason, compressed air is not recommended and I doubt you need that much pressure anyway. If you use compressed air, keep it under 5 psi.
Ok all that said, you don't have to baby this job of fishing a line through the tube, just know you shouldn't muscle it either.
Finish this off by pouring some water down the drains. The water will appear on the garage floor behind the front fender wells and in front of the rear fender wells (if memory serves)
BrentGardner
29
Dec 16, 2024 12:13 AM
hafren
Aug 30, 2023 03:42 PM
innzane
Aug 27, 2015 07:58 PM
