water pump replacement,
Old Jan 26, 2018 | 04:21 PM
dvjag's Avatar
Default water pump replacement,
Can anyone give me any ideas on how to replace the water pump on my 2007 xj8, I have had a good search but cannot see anything, appreciate any help ,
thanks
Dave
2007 xj8
Old Jan 26, 2018 | 04:34 PM
NBCat's Avatar
Use this link and scroll down to Workshop Manuals, Powertrain...
https://www.jaguarforums.com/forum/x...k-links-20085/
Water pump removal begins on page 90.
Old Jan 26, 2018 | 04:44 PM
XJ8JR's Avatar
I did it twice on my old 05 XJ8. If you're handy, it's not difficult at all. Here's a very basic step-by-step:
1. You'll have to drain the coolant first. Refer to the attachment.
2. Remove the air intake tube.
3. Disconnecting the big coolant hose and moving it aside will give you more room to work.
4. Loosen the water pump pulley bolts before removing the belt.
5. After belt is removed, remove the water pump pulley.
6. I think there's 4 or 5 bolts that hold the water pump to the engine. Remove those and pull the pump free.
7. Clean up all the mating and nearby surfaces and then bolt the new pump on with the new gasket. I always use a tiny bit of sealant to help keep the gasket on straight during installation.
8. Tighten water pump bolts to 8nm + 90 degrees. Reinstall pulley but don't tighten bolts yet.
9. Reinstall belt. Refer to attachment.
10. Tighten pulley bolts to 10nm + 45 degrees.
11. Reconnect the big coolant hose and reinstall the intake tube.
12. Refill and bleed the coolant, as per the attachment.
13. Grab a Guinness.
Old Jan 26, 2018 | 04:45 PM
XJ8JR's Avatar
NBCat beat me to it.
Old Jan 26, 2018 | 05:45 PM
abonano's Avatar
Use a 6 point socket to remove the bolts. Last thing you want to do is round the bolt head. (Take it from experience...)
Also, follow torque spec and use a torque wrench. Sometimes once you get to the 8Nm the +90 deg is hard to accomplish.
Some bolts may only go +45 to +60 deg. Off that happens don't force it to +90 deg.
It's ok provided you get to the 8Nm.
Old Jan 26, 2018 | 06:11 PM
dvjag's Avatar
thank you guys, will wait till the warmer weather and will do the job then,
Busa196
Jan 13, 2025 04:33 AM
Candy's Kitty
Sep 19, 2012 02:41 PM
SteveM
Oct 12, 2010 09:57 AM
AntixSD
Apr 3, 2010 07:40 AM
