Weather striping for doors
Old Jun 19, 2018 | 10:51 PM
Panelhead's Avatar
Default Weather striping for doors
the rubber weather striping on the front and rear door has crumbled at the bottom. Only on the driver’s side.
Is there a cheaper source than dealer?
Old Jun 20, 2018 | 09:46 AM
Sean W's Avatar
What year and model? Are you talking about the rubber attached to the fabric or something else? And if you are, what color?
Old Jun 20, 2018 | 11:38 AM
Panelhead's Avatar
Default I hate spell correction sometime
what I am looking for is the soft black rubber door seals that are attached to the body. Weatherstripping.
The rubber is only bad at the bottom and only on drivers side. Passenger side is holding up. The rubber on the doors is okay.
It was crumbing when car was purchased three years ago. By using several rubber rejuvenator products it is still the same.
But since all the other issues are fixed right now I thought is a good time to fix this.
Old Jun 20, 2018 | 12:16 PM
Fraser Mitchell's Avatar
Please tell us what car you have to make sure the answer below is correct.
You've posted in the X350 model series forum so your car should be one of these built between 2003-2009. AFAIK Jaguar are the only source for these seals on these cars either at a dealer, or sold via an internet Jaguar specialist.
Old Jun 20, 2018 | 12:33 PM
Sean W's Avatar
^^^^^ what he said and a pic would be helpful to Panelhead
Old Jun 20, 2018 | 05:07 PM
meirion1's Avatar
The rubber on these Jags is very poor.
Best bet is to find some used rubber seals I doubt that it is available on the aftermarket.
Old Jun 20, 2018 | 06:41 PM
Panelhead's Avatar
Default 2006 XJR
It is a 2006 XJR. Blue/grey color.
Old Jun 21, 2018 | 02:04 PM
I'm thinking the heat of Houston has made these seals deteriorate quicker than they do here in England, as mine are in vg condition. On my last car they were also OK except there was a tear at the bottom of the front passenger door seal that I had to glue-up
Old Jun 21, 2018 | 02:29 PM
Panelhead's Avatar
Default Who knows
it is only deteriorated at the bottom of the driver side doors. Paint and interior are not faded on any side.
I suspected it sat where the afternoon sun cooked it. But should get the top also.
When I first saw the boots on the ball joints and other rubber suspension I wondered if car had been soaked in gasoline. The lower seals look like the ball joint boots.
Old Jun 27, 2018 | 06:10 PM
kg74's Avatar
I had the same issue. What I did was remove the plastic trim strip on the bottom (floor board) and then removed the entire seal. I placed the damaged seal sections under the trim strip, coated it with some sealant, let it dry and then installed plastic protective cover. Basically I just moved the damage section to where it didn't matter as it is covered with the trim. As the joint has moved - I carefully used the same sealant to seal the joint.
Old Jun 28, 2018 | 12:49 PM
Panelhead's Avatar
How did you remove the rubber seal intact. The seal I need to remove is glued to the car body. It does not go under the door sill plate.
Old Jun 28, 2018 | 03:59 PM
kg74's Avatar
Panelhead: Post a picture of what rubber seal you are talking about. Mine was not glued in.
jagtoes
Mar 5, 2017 12:44 PM
jagtoes
Aug 11, 2015 09:25 PM
Darrenmb
Nov 20, 2014 02:09 PM
al_roethlisberger
Jun 29, 2014 07:51 AM
Rayzor61
Dec 2, 2013 05:02 PM
