What did you do to your X350/X358 today?
Old Sep 26, 2017 | 11:15 PM
  #361
Wingrider's Avatar
Or get three more and be done for a while.
Old Sep 27, 2017 | 12:22 PM
  #362
XJ8JR's Avatar
Yeah I know I should but I can't stand replacing them while they're still working.
Old Sep 29, 2017 | 08:18 AM
  #363
Wingrider's Avatar
Well the three old ones can become the spare's that you'll never need. Spare parts come in handy on occasion
Old Sep 29, 2017 | 08:50 PM
  #364
abonano's Avatar
My neighbor (mechanic) installed and balanced my new Nitto Motivo 20" tire today...
Attached Thumbnails What did you do to your X350/X358 today?-20170929_184151.jpg
Old Sep 30, 2017 | 03:43 PM
  #365
John Fox's Avatar
New Arnott front struts installed and I'm in love all over again.
Old Sep 30, 2017 | 04:17 PM
  #366
Fraser Mitchell's Avatar
We took her for a drive !! And to the Oil Can Cafe too !
The Carding Shed | Home of The Oil Can Cafe, High Society Clothing, The Retro Shed & IK Classics Garage Services
Old Oct 2, 2017 | 08:34 PM
  #367
djpxk8's Avatar
Fitted a near left side rear parking sensor, now all the parking aid sensors work and I do not have to listen to that 3 second beep when I put in in reverse...wonderful.
Old Oct 4, 2017 | 01:09 AM
  #368
bonanza's Avatar
Today's work
Oil/filter change
Diff oil change
Started replacing the thermostat housing, a corroded bolt broke...need to break out the drill tomorrow!!!!
Old Oct 4, 2017 | 03:00 PM
  #369
jackra_1's Avatar
Managed to throw a PO171 and a PO174. Drove several miles home before "restricted performance" came up.
Luckily came across the issue within about 60 seconds.
In the picture you can see the vacuum tube to the throttle body area behind the brass connector where it is supposed to be attached.
How the heck it came off is a mystery to me. I did put a little gasket maker on the brass connector before reinstalling the tube.
Old Oct 5, 2017 | 12:03 PM
  #370
Six Rotors's Avatar
Default God's Country!
Ah yes, God's country! If you looked across to Castle Hill, I lived just a few miles beyond near the Emley Moor TV tower.
Old Oct 5, 2017 | 11:33 PM
  #371
bonanza's Avatar
Managed to drill out the broken bolt (Post 368) and finished the thermostat housing replacement.
Changed the broken hood(bonnet) cable.
The snag list is getting smaller.
Old Oct 15, 2017 | 03:19 PM
  #372
abonano's Avatar
I cleaned & polished my chrome exhaust tips and cleaned up the plastic lip right under the rear bumper with "back to black" plastic restorer.
What a difference!
Old Oct 16, 2017 | 12:12 PM
  #373
Fitted a set of 17" Elegant wheels to replace my 19" Polaris. I found the ride rather too harsh, and the worst bit is the vulnerability to kerbing. Hell, you've only to look at the kerb whilst parking and a wheel is kerbed. With the new wheels, the tyres are "fatter" therefore the tyre contacts the kerb well before the rim. The wheels are quite a few years old, yet virtually unmarked. Ride now is much more compliant. Tomorrow I will have the two front tyres replaced as one is a 2003 Pirelli P6000 and the other a 2007 Kumho Solus. Rears are 2016 Kumho Ecowings with a lot of tread left, so I'm going to run these for a while.
Old Oct 16, 2017 | 10:14 PM
  #374
wforslund3's Avatar
I vacuumed trunk and interior, then drove it. We got this 04 XJR 3 weeks ago....
dang thing is FAST and I love it, even though I know it will be a bit fickle. Glad this forum exists as it is where I have found all the answers for our X type.
Old Oct 16, 2017 | 11:03 PM
  #375
MrWhite's Avatar
Today, I changed the oil and filter. I also flushed the coolant by draining, and refilling with distilled water 5 times. Last refill was with straight Dex-Cool to achieve the correct mix. fairly easy job, but time consuming what with waiting for it to come up to operating temp and then cool back down 5 times.
Old Oct 17, 2017 | 04:34 AM
  #376
clifton94's Avatar
Replaced a noisy water pump and aux belt while I was doing the job not a bad job to do just a little bit fiddly in places as there's not a lot of room
Old Oct 17, 2017 | 04:10 PM
  #377
XJ8JR's Avatar
What kind of noise was the water pump making?
  #378
So today, a pair of Toyo Proxes was fitted. They seem OK so far and cost me around £200 for the pair. I am now very happy with the ride and hope to keep the car for many years yet.
Old Oct 18, 2017 | 03:44 AM
  #379
clifton94's Avatar
Hi xj8jr sounded like a noisy bearing but the noise went after a minute and only done it when it was cold sometimes it never made a noise at all, initially I thought it might be the supercharger as the noise seem to be in that area so i left the car over night then I drained the cooling system and removed the header tank and the supercharger belt and started it up noise was still there,so I removed the aux belt and spun all the pulleys to make sure all were good and the only slightly noise one was the water pump if I turned it slowly you could feel the roughness in the bearing so I replaced it and all is quite again.
Old Oct 18, 2017 | 06:14 AM
  #380
Wingrider's Avatar
Persistence pays off, gotta keep at it to get er done.
