What did you do to your X350/X358 today?
Old Aug 16, 2021 | 07:22 AM
  #1241
yellowbandit's Avatar
Originally Posted by James Teddy Gillis
Used JLR to update ECU and TCU.
Can you tell me more about this? I purchased my car last year, and I’m sure it hasn’t seen the inside of a dealer in years. What would i actually ask them to do, and what benefits could I expect?
Old Aug 17, 2021 | 03:46 PM
  #1242
StagByTriumph's Avatar
@Yellow Bandit
The dealer will probably not replace the ECU or TCM unless either under a warranty, Factory Recall or if the ECU and/or TCM are fully diagnosed not functioning. Most dealers have a flat fee for diagnosing and upgrading to the last factory revision and I have found it is quite reasonable, less than $200 at some dealers.
Of course if you tell them you want to replace them regardless I am sure they will probably gladly accept your money - expect all that work to total in the range of $8k-$10K performed and warranted through a dealer, IF the dealer can locate the all new Jaguar Parts.
Note that a JLR dealer will only use New Genuine Jaguar parts, and can only substitute if there are no factory approved parts available. Most of that is due to liability issues.
Now if you have a friendly chat with the shop manager they might look for and reprogram used parts, but I doubt they will warrant them other than the labor.
Old Aug 17, 2021 | 04:33 PM
  #1243
Ah. So it's "Check my ECU and TCU and be sure I'm running the latest software?"
I think I may need to invest in this! Is there a way to see what dates revisions came out so that I can check against the last time my car was in a dealership (according to CARFAX)?
Old Aug 17, 2021 | 05:29 PM
  #1244
James Teddy Gillis's Avatar
Originally Posted by abonano
Nice, but put NGK factory spark plugs back in...
No thanks. GREAT plugs but its happy. Tell you what, line up on a 40 roll and let's see how the plugs do
Old Aug 17, 2021 | 05:36 PM
  #1245
I would imagine now days the dealer will do mostly what you asked as long as its not outside their liabilities. And a Manager may do anything but have you sign a waiver. I have a JLR/SDD updated to 2017. So I didn't need the dealer. Here in Miami they do not care. As long as you are paying, lol. Though I must say if you have a good rep with an advisor, cash will get the tech to do whatever, IJS. I believe investing in. JlR is a good idea. You can do so much more.
Old Sep 1, 2021 | 09:39 PM
  #1246
J.A.G.'s Avatar
Default Some interior replacements.
During the last weekend, I was doing some changes in the interior, I was curious about combine others colors and I put a Black center console instead of the original because I wanted to have a better match with the stereo, I replaced the doors panels; I bought the material and made them, since that was my first time working with this kind of materials I think turned out well, I did the same with the center console, but just the bottom.
I have some others ideas for the trunk, but that will be later in a few weeks.
Center console
Old Sep 2, 2021 | 05:43 PM
  #1247
novice19's Avatar
Default Modifications made in factory entertainment system
I had my premium entertainment system upgraded. First of all I had Jagdroid installed in my original Navigation system. As a result :
New touchscreen with HD resolution was installed
Android capability was added
BT Audio receiver dongle was installed to stream audio from the phone
A rearview/backup camera was added
Underseat Subwoofer was added
I added a converter to enable Apple Carplay
Attaching some photographs of the car that I washed today and the modified entertainment system
Old Sep 2, 2021 | 05:49 PM
  #1248
J.A.G.'s Avatar
QUOTE=novice19;2435660]I had my premium entertainment system upgraded. First of all I had Jagdroid installed in my original Navigation system. As a result :
[/QUOTE]
Amazing
​​​​​​That's a clean Cat! Amazing.
Old Sep 2, 2021 | 08:02 PM
  #1249
novice19's Avatar
Thankyou!
Old Oct 10, 2021 | 06:31 PM
  #1250
joeleerj's Avatar
Default Vibration in rear end
I have been noticing a vibration in the rear end at highway speeds.So I finally checked it out and found the problem.The upper control arms and half shafts were shot. So I replaced them..
Changed both half shafts, threw the other one away before picture
Old Oct 11, 2021 | 10:40 AM
  #1251
J.A.G.'s Avatar
Nice, you did it by yourself? That's something that I need to check as well.
Thanks for th post.
Old Oct 11, 2021 | 04:24 PM
  #1252
meirion1's Avatar
How many miles on the vehicle?
Old Oct 11, 2021 | 05:18 PM
  #1253
joeleerj's Avatar
Exclamation
Thanks for the post.
Yeah, I did it myself. Not a difficult job. Just had to remember to disconnect to brake hose at the calipers.
Old Oct 11, 2021 | 05:19 PM
  #1254
joeleerj's Avatar
A little over 165,000
Old Oct 11, 2021 | 05:22 PM
  #1255
J.A.G.'s Avatar
Default Thanks
Originally Posted by joeleerj
Yeah, I did it myself. Not a difficult job. Just had to remember to disconnect to brake host at the calipers.
Thanks for that detail about the brakes.
Old Oct 11, 2021 | 08:29 PM
  #1256
joeleerj's Avatar
No problem. Didn't want you to be surprised.
Old Oct 12, 2021 | 12:55 AM
  #1257
Etypephil's Avatar
It's perfectly entitled to request a few replacement parts. Having owned some 89 cars including 25 Jags, 8 BMWs, and 4 Mercedes Benz, it never ceases to amaze me how well X350s and X358s stand up to time and miles. It can be difficult to tell a 50,000 mile car from a 250,000 mile one without checking the odometer.
Old Nov 17, 2021 | 02:49 PM
  #1258
Petz's Avatar
Default 2003 xj8 337000km
Currently trying to get the airfilter hose out of the plummerfitting on the original compressor (the one near the piston)
oil change is done the new compressor with dryer is waiting to get running
Old Nov 17, 2021 | 03:06 PM
  #1259
abonano's Avatar
Spray connection with a bit of WD40 - use the open end of a 12mm wrench - press down on the fitting, while pulling tube out.
Old Nov 17, 2021 | 04:15 PM
  #1260
Petz's Avatar
Laid a 12 then a 14 and a 16 on top of each other to give it some slight tapping with a hammer while using a prytool underneath the hose.
i already have a next idea for tomorrow.
i also opened and removed the bore /piston section and sprayed some dw 40 from underneath
