What type of engine oile should I use ?
Old Oct 26, 2019 | 07:32 AM
Alex88's Avatar
Default What type of engine oile should I use ?
Hi everyone, I want to change the eng9oile to my xj8 4.2 2003, and don't have the book.I saw different specifications and different oils used ,also what key I need to take the oil filter off.Thank you.
Old Oct 26, 2019 | 08:43 AM
Partick the Cat's Avatar
The Jag specification (in the handbook) is Jaguar (Ford) M2C-913-B (or -C, or-D).
Old Oct 26, 2019 | 09:54 AM
Clapton7's Avatar
Old Oct 26, 2019 | 09:59 AM
Here is the relevant page from the UK Driver's Handbook. I've sent a PDF copy of the Driver's Handbook to the eMail address you have registered with the forum.
Note that the specification and viscosity are the important criteria. Castrol is a premium brand recommended by Jaguar because they have a commercial contract with them. Any premium brand motor oil meeting the specification is suitable.
Old Oct 26, 2019 | 12:32 PM
Alex88's Avatar
Default Thank you all!
How much oil roughly will need 6liters?
Old Oct 26, 2019 | 01:51 PM
Panelhead's Avatar
Sounds right, mine holds a little over 6 quarts. Oil specs have evolved since 2003. SN is the latest spec.
Been using European Castrol 0-w40. In the XJR, A8, and 335i.
Changed the other cars over Rotella Truck 0-w20. It is 21.68 per 5 quart jug at Walmart. May change to the Rotella 5-w30 In the European cars when all the Castrol runs out.
But all this is overkill. Any brand synthetic speced SN is better than required.
Old Oct 26, 2019 | 01:59 PM
Here's the volume required for an oil and filter change:
Buying engine oil in 1 Litre containers is more expensive than buying it in 4 Litre or 5 Litre containers.
Boeingtravel95
May 11, 2018 10:31 PM
pk4144
Aug 27, 2017 07:10 PM
Cableman
Apr 6, 2015 12:39 PM
i h8 hites
Feb 1, 2009 07:18 PM
RagtopJag
Sep 9, 2008 07:31 PM
