Where is the computer?
Old Mar 14, 2015 | 04:34 PM
XxSlowpokexX's Avatar
Default Where is the computer?
Silly question but I really have no idea where it is. AND is it difficult to pull
Thanks!
Old Mar 14, 2015 | 08:36 PM
dsetter's Avatar
Which computer, there are several, engine, transmission, body, entertainment, climate, etc.
Old Mar 14, 2015 | 08:51 PM
Cambo's Avatar
If you mean the ECU it's under the glovebox, remove the carpet trim under the glovebox and you'll see it. It's held in with some security Torx bits, from memory they are 5-point instead of the usual 6-point.
Old Mar 14, 2015 | 11:36 PM
Don B's Avatar
Also, the ECM connector is accessed from the engine bay, under the cabin microfilter housing, which must be removed. The manual states that you must remove the windshield wipers and windshield cowl, but I was able to get the microfilter housing out by just removing the fasteners on the right end of the cowl and moving it up out of the way (I didn't touch the wipers). The harness connector attaches to the ECM with one 5-point security Torx fastener that remains in the connector once loosened. The security Torx fasteners have a central pin so your bit must have a center hole. I found an inexpensive set on eBay.
Cheers,
Don
Old Mar 15, 2015 | 08:21 PM
The EEC thank you all very much!!
Old Mar 16, 2015 | 02:00 PM
JagV8's Avatar
It'll not be faulty...... (well, almost for sure)
Old Mar 17, 2015 | 07:45 AM
Seems like it will be fun. Ill do it this weekend. Finally getting to it to get it reflashed
trickeyM
Feb 29, 2020 07:00 PM
trickeyM
Oct 4, 2015 05:43 PM
mat32essex
Oct 3, 2015 04:12 PM
zoozth
Sep 29, 2015 07:28 AM
