XJR engine/drivetrain improvements?
Old Feb 16, 2019 | 06:47 PM
rosskuhns's Avatar
Default XJR engine/drivetrain improvements?
I can't seem to find any information on this - searching the interwebs and here What, if anything, besides electronics etc, did Jaguar upgrade on the XJR's? i.e. pistons/crank/rods etc. I also found a mention that the ZF tranny was an upgrade from the XJ8 6 speed? true or not?
What other driveline upgrades. I know the brakes and suspension, quicker steering too I believe?
Old Feb 17, 2019 | 04:52 PM
rosskuhns's Avatar
168 views so far and nobody knows if the XJR engine was improved for supercharging duty over the XJ8?
dag.
Old Feb 17, 2019 | 05:20 PM
Cambo's Avatar
There's a difference between not knowing and not caring enough to post...
Old Feb 17, 2019 | 05:26 PM
Cambo's Avatar
Same crank
Different rods and pistons
Oil squirters added to supercharged block to cool the pistons
Different oil thermostat and filter block, different oil cooler
Different exhaust manifolds, cats and exhaust
The pre-06 cars had different cams and were without VVT
The whole intake system is different, obviously
Transmission got extra clutches to handle the increased torque
Same steering rack regardless of engine
Bigger brakes on the Supercharged
Old Feb 17, 2019 | 06:40 PM
JCalhoun's Avatar
The supercharged X-350's also have an extra electric water pump for the intercoolers, and an extra fuel pump to boost maximum flow.
JC
Old Feb 18, 2019 | 07:00 AM
rosskuhns's Avatar
Thanks cambo, thanks calhoun - I was just thinking 'where's cambo?'.
so it did have a different tranny ZF. No quicker steering.
oil squirters - nice. I'll assume the pistons lowered the compression ratio.
I'm looking at an '04 XJR and the info has been surprisingly difficult to find. Usually you find the articles when a new car comes out and they have a nice list of differences right from the manufacturer to the journalist to tout all the goodness.
Old Feb 20, 2019 | 10:45 AM
JagV8's Avatar
A lot of it or all of it is in the Jaguar doc such as the various Technical Guides. Many are on the forum / the net / with JTIS. Worth reading if you're interested.
Old Feb 21, 2019 | 12:42 AM
cornershop's Avatar
Old Feb 23, 2019 | 06:11 PM
rosskuhns's Avatar
And here's the 2004 tech guide Jag Repair is nice enough to house...wow, I wasn't really expecting to spend an hour plus reading through that thing, fascinating.
​​​​​​http://www.jagrepair.com/images/Auto...ch%20Guide.pdf
From some notes I made while reading (to add to the good info above)
*XJR got solid axles vs tubular on NA's.
*Brembo brakes have a separate rear ebrake caliper.
*XJR uses aluminum forged pistons vs. cast in NA engine. 9:1 vs 11:1 comp ratio
*Both have sinter forged rods - read up a bit on these; and they seem to be as strong or arguably better than forged rods
*XJR has a thermostatically controlled oil diverter valve to the oil cooler.
*XJR has an intake control flap - at high demand it opens a flap in the intake box to let more air get through
*Different muffler internals - I found a note saying something like 'each configuration has different rear muffler internals'
*Cat sizes are different in exhaust; as well as log stainless manifolds as cambo noted
Interestingly I found a note that say all V8's use a smaller steering pump pulley.
XJR's also have:
Sport seats "R-performance"
full leather steering wheel
de-chrome exterior package
8.5x19 rims
R leather gear shift knob
Old Feb 24, 2019 | 01:49 AM
cornershop's Avatar
Yes, I linked the 06 version as this is when they introduced VVT on the XJR (the NA had it prior to 06) - quite a few changes introduced in 06.
Higgins
Nov 22, 2021 04:58 PM
goodpoint
Dec 19, 2018 03:23 PM
JaguarXJR02
May 18, 2013 09:11 AM
JimC64
Aug 1, 2007 02:45 PM
