1996 Sovereign Locking
Hi,
Neither fob is working (have replaced batteries and lights work).
if I press the valet button 5 times there is no beep.
if I press the valet button once the boot is locked and will only open with the key, not with the dash button or the bottom on the boot.
if I lock the car with the key and then unlock it, the boot now will still only open with the key unless I unlock it with the dash button, at which point the button on the boot works again until the car is locked.
Ive searched old posts and can’t see anything quite the same.
Questions:
is the first step to replace the locking module, or is there any diagnostics/tests that can be done first?
thanks for any help/advice.
Questions:
Welcome to the forum Swigbert,
The word "Sovereign" is a subtle hint you may have posted in the wrong forum. I presume you have the 1996 four door XJ6 a.k.a. X300 and not the 1996 two door XK8 a.k.a X100? In either case, the last thing rather than the first would be replacing the locking module. Confirrm which model you have and I'll move the thread if necessary.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
iconic
03-03-2016 01:51 AM
