1999 XJ8 --> 1997 Headlights
I can't remember where I read it, but I am looking at converting the 1997 XJ6 Healights to 1999. Is it possible, and does anyone know where I would find the wiring differences,
If I remember correctly , the small bulb courtesy lights are on the inboard lens on one x300 and the opposite outboard on the X308 or vice verso
It could be the highs on the inboard and then outboard positions
Best to mark with tape the position ( and up ) of the lens assemblies before swapping around least when you put it all together the curves of the hood will not fair in
Very frustrating
as to the connector wiring .........................
researching
I hate it when they have the different names for
High Beam =
Low Beam =
What he is referring to as sidelight is the courtesy light that only stays on for so long as you exit the vehicle at night
Very frustrating
researching
High Beam =
Low Beam =
You can pull either the high or low beam relay to know the other wires are hot , or fuse
So for the X300 the low wire colors are
and high wire colors
Crossing X300 wire diagram........................................... ............
For the left
Pin 4 and 5 Black ground............................................ ...............same on X308 ( 1999 ) bulb socket
Pin 3 ( Blue / White ) main beam hot...........................................Blue / Black
Pin 2 ( Blue / Yellow ) dip beam hot............................................... .Blue / Yellow.
Pin 1 ( Red / Pink ) pilot light hot only on exiting car....................Red / Pink
For the right
Pin 4 and 5 Black ground............................................ .............same
Pin 3 (Blue / White ) main beam hot.....................................Blue / White
Pin 2 (Blue / Yellow ) dip beam hot...................................... Blue / Pink
Pin 1 ( Purple / Yellow ) pilot light hot.................................Red / Yellow
Now matching the colors up with the X308 ( 1999 ) as the X308 bulb connector pigtail........................................... ...
I'll have to go back and double check my table in a bit
For the left
For the right
For those wishing to do it. I found this post from @The Black MUNK
"The X308 headlight swap is easy. I just bought the complete units with the mounting brackets from an on-line breakers, see attached photo. You need to get the harness connector blocks too, as they are different between the X300 & X308. They came with the bulb, which are also different. The connectors need to be swapped over and the wiring colours are different. You need to either cut & solder the wires between the two, or get new crip connectors for the blocks.
The colours are:
RH
CAR - X308 light connector
Black - Black
Black - Black
Purple/White - White
Blue/Yellow - Blue
Blue/White - Orange/Yellow
LH
Black - Black
Black - Black
Red - Red/White
Blue/Yellow - Blue/Yellow
Blue - Blue/White"
The colours are:
RH
Black - Black
Black - Black
Blue/Yellow - Blue
LH
Black - Black
Black - Black
Red - Red/White
Blue - Blue/White"
After looking at the x308 connector these colors are not correct.
I believe they are
RH
Black-Black
Black-Black
Purple White-Red/Yellow
Blue/Yellow-Blue/Purple
Blue/White-Blue/White
LH
Black-Black
Black-Black
Red-Red
Blue/Yellow-Blue/Yellow
Blue-Blue/Black
I believe they are
RH
Black-Black
Black-Black
LH
Black-Black
Black-Black
Red-Red
Blue-Blue/Black
Somewhere around 1999 they had some wiring changes as this related to an engine upgrading from the AJ26 to 27
The AJ26 engine had no steel sleeves in the cylinders causing compression problems ( nickosil coating reacting to sulfur in fuel , eroding compression to even start )
I only noticed a couple changes notably the AJ27 MAF connector pin map
Added some information that might be helpful since the 1998 electrical guide does not spell out the headlights and colors. It does detail out the fog lights very well
RH
Black-Black. **Ground
Purple White-Red/Yellow. ***Pilot
Blue/Yellow-Blue/Purple. ***Dip
Blue/White-Blue/White. ***Main
LH
Black-Black **Ground
Red-Red. ***Pilot
Blue/Yellow-Blue/Yellow ***Dip
Blue-Blue/Black ***Main
RH
LH
Red-Red. ***Pilot
Dipped lights, also known as low beam headlights, are the standard headlights on a vehicle that are used for driving at night and in poor visibility. They are angled downward to illuminate the road ahead without blinding other drivers:
