4L80-E gasket - Purchase?
Old Jun 15, 2014 | 11:32 AM
AlbBolivar's Avatar
Default 4L80-E gasket - Purchase?
I purchased a transmission filter kit from Autozone and tried to install the included gasket but I guess there are different variants of the 4L80-E gaskets and the one I purchased was for a different type so I have a leaking transmission pan.
I'm wondering where everyone purchases their gaskets from that are made specifically for the Jaguar 4L80-E pan.
Looks like that one I need is this
Which is more rectangular than the one I bought
Is the Jaguar specific gasket available in regular autoparts stores like Autozone or Oreilly's?
Old Jun 15, 2014 | 12:27 PM
Chattanooga_XJR's Avatar
All the autoparts stores list the ZF kit for the XJR. Go ask for kit for Chevy Tahoe or Avalanch like 98-00 model and it will say 4L80E. I had same thing happen. You get to make them look like dummies when you tell them that I tried all the major stores and they were all wrong but those Chevy's have same tranny, the new seal looked worse than the one I bought so I reused the old seal and put the new filter in. I forgot to do this on mine but cut open your old filter to see if there are any particles inside. It will trap most so you won't see much in the pan unless you're in bad shape.
TLR Nothing special as far as the seal or filter is concerned regarding this 4L80E so just ask for 4L80E seal.
Old Jun 15, 2014 | 01:24 PM
Doug's Avatar
Mine has one of those reusable gaskets so I've never faced this problem....so I can't help.
Some of the transmission parts specialists show a Jag-specific 4L80E pan gasket. You might have to buy from one of them. There likely isn't enough demand for this gasket for the typical franchise-type parts stores to supply it via their normal supply/distribution network.
Old Jun 15, 2014 | 01:28 PM
AlbBolivar's Avatar
Thank you. I was actually on the phone with an oreillys as I was reading your post so I asked about the Chevy seal and they confirmed that it was the same application.
Old Jun 15, 2014 | 01:30 PM
AlbBolivar's Avatar
Doug, I actually was looking into a reusable gasket but since I was assuming I picked up the right gasket I already have my transmission pan off and don't really want to wait a few days to order it online unless I have to. But I am looking at a reusable gasket from summit racing. Do you have any recommendations as to where I should order one if it comes down to it?
Old Jun 15, 2014 | 03:00 PM
Doug's Avatar
I'm getting a bit confused. Are we talking about a 'seal' or a 'pan gasket'? The two are not usually used interchangeably in this context.
For a pan gasket just Google '4L80E pan gasket Jaguar' and you'll see some listing for a Jag-specific part.
Old Jun 15, 2014 | 03:41 PM
AlbBolivar's Avatar
Sorry for the confusion. I'm talking about the pan gasket. Edited my last post for avoid confusion
Old Jun 15, 2014 | 04:42 PM
Jagboi64's Avatar
Is there a Jaguar specific pan gasket, or is it the same shape as the Chev transmission?
Old Jun 15, 2014 | 05:04 PM
AlbBolivar's Avatar
There is a specific Jaguar shape. I've looked online and did some researched and this website shows the difference 4L80E, 4L85E Gaskets & O rings Transmission Parts
I called an oreilly auto parts earlier and they told me they have the gasket. Hopefully it's the correct Jaguar one or else I am going to have to order online.
Old Jun 15, 2014 | 09:21 PM
It's the exact same shape as the Chevy.
Old Jun 15, 2014 | 11:33 PM
AlbBolivar's Avatar
The one I removed from my transmission pan was this shape..
And the ones I can pick up from any regular autoparts store (Autozone, Oreilly's, Pepboys) is this shape
but they all say this fits the 97 XJR
Both claim to be 4L80-E with nothing saying they're different. Is there a VIN specification for the different pans? The last six of my VIN is 792115
This website shows the differences and lists the specifications for each gasket
Are you saying your pan uses the more common one Chattanooga_XJR ?
Attached Thumbnails 4L80-E gasket - Purchase?-34300ejf.jpg   4L80-E gasket - Purchase?-34300ef.jpg
Old Jun 16, 2014 | 12:15 AM
The one I got from Advance Auto matched exactly, had them both side by side to compare. So idk, sounds like you'll have to order online if your local stores don't have exact match.
My last six on my VIN is 793473
Old Apr 6, 2022 | 04:48 PM
FerrariGuy's Avatar
Because a friend was looking for this gasket and I hit this thread as part of looking for it. So adding this for archival use:
NatProNet.com appears to make the duraprene bonded gasket under PN 33170J: https://www.natpronet.com/trans/4L80E.pdf
https://natpronet.com/
https://www.oregonperformancetransmi...TP-33170J.html
~Paul K.
aholbro1
Dec 29, 2024 06:46 PM
vicom
Sep 17, 2015 03:32 AM
Bob Gelston
Sep 14, 2015 11:08 PM
1964Daimler
Sep 9, 2015 11:20 AM
hoodun
Sep 7, 2015 07:02 PM
