'97 X300 VDP Inertia Switch Location
Old Jul 3, 2013 | 09:25 AM
Selsoft's Avatar
Default '97 X300 VDP Inertia Switch Location
Where is the inertia switch located on a '97 VDP?
I removed the plastic cover under the front passenger kick-panel, and did not see a switch there.
[The arrow in the picture points towards the passenger seat]
Old Jul 3, 2013 | 12:53 PM
jimbov8's Avatar
I'm not sure, but you may be looking on the wrong side. However, take off the front footwell side panel on the passenger side to see if it is in there. If not it will be in the drivers side either above the pedals or behind the footwell side panel.
Hope this helps.
Old Jul 3, 2013 | 04:26 PM
Selsoft's Avatar
Hope this helps.
Thanks, I found it on the passengers side footwell side panel, towards the front of the car. On another note, depressing it did not resolve my start up issue ...onto checking battery level ...if not, then I suspect the security system is engaged ..
Old Jul 3, 2013 | 06:39 PM
Selsoft's Avatar
Originally Posted by Selsoft
...did not resolve my start up issue ...onto checking battery level .. ..
Battery level reads 2.3V.
I think that is the root-cause of the car being dead [i.e. no crank, no lights, nothing, just quiet]
Old Jul 6, 2020 | 11:01 AM
Richy's Avatar
Default Picture plz?
I still cant find it. If you could send a photo of where it is located and highlighting what im looking for that would be amazing
Old Jul 6, 2020 | 01:47 PM
Parker 2's Avatar
This is for a right hand steering model with the pedals on the right
A left hand steering model will still have the ECU and inertia switch on the right side fwd of the door hinge
The ECU is under a small plastic cover that has been removed in this pic from someone else
To make the circuit , jumper the 2 white wires ( the 3rd black wire socket you will leave alone ) with a paper clip and this will enable the car to run , works from experience
The inertia switch does not always reset from reading
44lawrence
Apr 22, 2020 07:33 AM
InsaneXade
Apr 20, 2017 03:59 PM
JagfanNYC
Nov 5, 2012 11:41 PM
John Fox
Dec 28, 2011 11:07 AM
jdbryant
Mar 16, 2009 08:40 PM
