97 XJ6L windshield wiper problem
Old 03-21-2018, 04:48 PM
haroldpeacocksr's Avatar
Exclamation 97 XJ6L windshield wiper problem
the wiper on my 97 XJ6 quit working, motor checked out fine, tried changing the column switch that didn't help relay still blowing out, , ,any suggestions?
thanks.
Old 03-21-2018, 06:14 PM
Lady Penelope's Avatar
Received 1,383 Likes on 1,087 Posts
By the relay blowing out is it the motor power fuse # 6 / 20 amp LH engine fuse box or the control # 16 / 10 amp RH heelboard fuse box in the below pic . Or 1 of the 2 relays # 5 or # 6 in the pic .
John P (05-29-2020)
Old 03-22-2018, 01:07 PM
Default wiper
First; thank you for your timely reply. I'm not with the car right now so I can't tell you which relay, so as soon as I am able I will get back to you with the info., again thanks
Lady Penelope (03-22-2018)
Old 05-25-2020, 09:10 AM
fatelvis's Avatar
Dear Lady P
Since "haroldpeacocksr" never replied to you, i'd like to use re-use this thread.
My XJ6 -97 keeps blowing F6 fuse. Even as ignition is turned off, when i insert a new fuse, it.ll blow immediately. Any hints to proceed?
Jari
Parker 2 (05-25-2020)
Old 05-25-2020, 01:01 PM
Parker 2's Avatar
Don't do that anymore
The # 6 / 20 amp fuse at point 71 is hot at all times and does not rely on a king relay or key rotation
All the fuses in the left engine fuse box are hot at all times , not so on the right
Pull the relay # 6 and see if the fuse blows
Pull the relay # 5 and see if the fuse blows
If not remove the motor connector and see if it blows again when you reinstall relay # 5 and # 6 both
There is a diode inside the motor that Tcasmarcus in Norway was able to replace
https://www.jaguarforums.com/forum/x...r-fail-120179/
See post # 19 and # 23 and you can private mail him for details on the part number
You gotta see his video , oh hell ya
fatelvis (05-26-2020)
Old 05-26-2020, 03:02 AM
fatelvis's Avatar
Thank you for detailed and swift instructions Parker 2. You and this Forum rock.
Jari
Parker 2 (05-26-2020)
Old 05-27-2020, 07:06 AM
fatelvis's Avatar
Default Progress!
I pulled the relay 6. Fuse blows. Pulled the relay 5. Fuse still intact. So the relay 5 is toasted. Got to buy a new one then. Can i plug 5 plug to 6 relay to be able to use wipers?
Old 05-27-2020, 10:16 AM
Parker 2's Avatar
The power passes through both relays in wire Yellow so you need both relays to eventually get to wire Blue ( slow ) or wire Red ( fast )
In pulling the suspect relay out and in your hand , the relay itself should read no continuity ( high infinite resistance ) between pin 4 and 5 on the relay in your hand , the pin 4 to 5 should read open
Do the 2 relays have the same part # ?
If so you can swap and see if you get the same results on popping the fuse
The part # LNA6706AA relay is used in many places on the X300 and you can swap it from the headlights ( right # 1 )or fog light ( left # 1 ) position
https://parts.jaguarlandroverclassic.com/parts/index/part/id/C50.C5064.C5064317.C50643173823/brand/jaguar/
See item # 1 for swapping options
Old 07-12-2020, 07:51 AM
fatelvis's Avatar
Got new relays and it did the job. Wipers are wiping beautifully. Thanks for your help.
Parker 2 (07-12-2020)
Lonestar
04-30-2019 12:03 PM
marvin.d.miller
01-24-2015 01:49 PM
Dgoose78
11-22-2014 09:54 AM
greygoose
09-21-2013 10:07 PM
nimtene
XJ40 ( XJ81 )
03-31-2011 06:49 PM
Quick Reply: 97 XJ6L windshield wiper problem
