Accelerator cable problems solved!
Old Dec 15, 2012 | 04:29 PM
jeremiahjaguar's Avatar
Default Accelerator cable problems solved!
I have a 95 xjr6 with a problematic throttle cable. It is broken at the plastic part that anchors the cable to the actuator. This has caused problems because I was never able to get a full 100% at wide open throttle due to the loose cable and I was unable to properly set the potentiometer causing performance problems, eventually the cable would get stuck and cause a high idle. Unable to find a new cable anywhere because this cable in no longer available as it just is not made anymore. I decided that all i needed was to replace the broken part for a new and improved replacement. Long story short I had the cnc shop draw up the plans and the will let me know the price for production on monday. The best part is that this replacement will allow you to use your existing cable and replace the broken plastic anchor with a cnc aluminum part, this should last forever. Should any one need one of these let me know, I will be getting mine made asap
Old Dec 15, 2012 | 08:25 PM
plums's Avatar
The cps sensor bracket got named the "Andy bracket".
So this is the "Jeremiah joint" then?
Old Dec 17, 2012 | 10:52 PM
Default jeremiah joint?
now the jeremiah joint, thats funny! maybe the name will stick. Whatever it will be called it will be ready in a week or two states the cnc shop, seems they are really busy and a one piece project just is not on the top of their list. Wow, one single piece by itself costs 250.00, shop says only will give discounts for large orders......I didnt want to spend that much on such a small piece but my car runs like &^%$# with the accelerator cable the way it is. I know what my car can do, any thing less just is not the same. might as well spend it or my kids will !!!!
Old Dec 18, 2012 | 12:11 AM
plums's Avatar
What about ends for a aircraft control cable then? They are available in crimp on style for various types of applications. Ask aircraftspruce.com for the paper or dvd version of their catalog. It has stuff that is not on the web site.
Old Dec 18, 2012 | 07:15 AM
Doug's Avatar
Mine's broken as well although, lucky me, the break is such that a simple wire tie makes a perfectly functional repair :-)
Old Dec 19, 2012 | 12:12 AM
Doug,
I was able to get away with my broken cable for about two years with the same zip tie method of holding into place. After time i was only able to achieve 90% or so at wot and car was just not performing to the best of its ability. With your cable the same way how much % of wot can you achieve? Im told that this is a common problem.
Old Dec 19, 2012 | 07:48 AM
Doug's Avatar
Originally Posted by jeremiahjaguar
Doug,
I dunno, but I'll check :-)
I've never "felt" like I was getting anything less than full throttle but ya never know.
Have you ever re-tensioned your cables? My experience is that they go slack over a period of time. This might cause a lack of WOT as well?
Old Dec 29, 2012 | 07:56 PM
Default replacement parts are in
The new accelerator cable anchor is in and I just wanted to share a pic in order for all to see. It feels great and the best part is i can now get the full 100% out of my potentiometer which will allow me to finally reset my potentiometer correctly. The shop made three and made me a deal on them.
Old Dec 29, 2012 | 11:15 PM
tmoore's Avatar
I would have made them for a lot less than $250.00.
TM
Old Dec 31, 2012 | 09:44 PM
jaguar1996's Avatar
I was reading what you posted and I have the same problem with my 1996 jaguar xjr just wondering if you fixed your problem ? Thanks
Old Dec 31, 2012 | 10:00 PM
doc's Avatar
doc
Are the items the you designed capable of being used on the cruise control side of the cable as mine is stuffed and the previous owner used some sort of resin to stop the cable coming loose
I have been suspecting this for a while as the reason my throttle not getting all the way open also with my sticking throttle I get some times
Old Dec 31, 2012 | 10:47 PM
yes it goes on the acctuator side of the cable, cruise control. I had the very same problems that you described, could not get 100% throttle, idle would stick at times. I put it together with superglue but it broke after a week. I used my cable for years broken at the end but eventually it gave me problems and I was unable to properly set my potentiometer because I couldnt get a 100% setting, at best it was 90ish. I had no other choice but to have this made as a new cable is no where to be found because they are no longer made. as soon as I get my sc back from magnum powers i will get my car together and reset my potentiometer as i now have full 100 percent throttle. I have only two left should anyone be interested, a good thing is you can use your existing cable, get rid of that broken plastic anchor for a cnc part that will never break.
Old Jan 2, 2013 | 04:59 AM
doc's Avatar
doc
jeremiahjaguar
Doc here
I would be interested in one of the other ones you had made
Old Jan 2, 2013 | 02:11 PM
please email me at jeremiahjaguar@yahoo.com, talk to you soon.
Old Jan 3, 2013 | 07:47 AM
jaguar1996's Avatar
How much will you sell one for?
Old Jan 3, 2013 | 11:53 AM
please email me at jeremiahjaguar@yahoo.com, price is reasonable. Just dont know if this discussion is allowed on this thread. Thank you.
Old Jun 19, 2013 | 04:41 PM
i held back on selling the remaining two cable anchors I have left because I had a problem with tps readings and wot percentages. Long story short the percentage of wot you will be able to reach is totally dependent on your current tps and what it currently reads. My old tps was able to reach 100% but when it failed i swapped out with two aftermarket and two oem original equipment and I have never been able to reach 100%, this was driving me crazy! But it was expained to me thats just the way things are and regardless of what percentage reads out on the scanner the throttle is open 100% I guess they dont make original tps/potentiometer they way they use too, wot throttle reads 95% and the car works fine. I have the last two available jeremiahjaguar@yahoo.com
Old Jun 20, 2013 | 09:48 PM
doc's Avatar
doc
I have just sent you an Email as I am up for one of the adjusters was just waiting till you sorted the problems out which it looks like you now have
toronadomike
Jan 22, 2026 10:13 PM
Gus
Oct 15, 2019 12:29 PM
ajacks86
Oct 12, 2017 08:51 PM
OkieTim
Sep 8, 2015 04:48 PM
XFR_Gold
Sep 2, 2015 12:24 PM
