Ain't Got No Defrost
Old Mar 24, 2023 | 06:05 PM
brianhough's Avatar
Default Ain't Got No Defrost
Hi everybody,
No defrost. I ran a climate control diagnostic, after I cleared the codes, I had a code 45 that didn't go away, which is the center vent motor. Would a problem with the center vent effect the defrost? Where is the center vent motor?
I found this link in regard to the defrost motor: https://www.jaguarforums.com/g/album/2731861 and was assuming the defrost servo was the problem, but now I'm not sure.
Any advice would be most welcome.
Old Mar 24, 2023 | 07:22 PM
Parker 7's Avatar
The trim door motors have both a motor and a position sensor
If the position sensor is the only bad part you can drive the motor to the position you want with a 9 volt battery and freeze the motor position
9 volt battery can run all the door motors and if you listen you can hear them run as a functional test
See page 78
T703 BOOK (jagrepair.com)
Witha code 45 Center Vent motor.........................
Pin 7 and 20 connector CC28 wuth the pink colored pins
This pic is for winter / summer bypass for a different issue
editing
Old Mar 24, 2023 | 10:24 PM
Parker 7's Avatar
Looking at the servo motor pics on page 76
Windshield defog is the second pic rear high on cars keft ?
Center vent servo is second pic on cars left ?
Old Mar 25, 2023 | 09:52 AM
Parker 7's Avatar
You might be able to reach under the glove compartment toward the center where the climate control ECU is located
Your connector would be toward the car's aft.........
Old Mar 25, 2023 | 11:15 AM
brianhough's Avatar
Thanks for your helpful reply Parker. That pdf is great. I have the instrument cluster out. There are two servos there. From your link, I believe one of them is the center servo. I might try to take it apart if I know it's defective. Doesn't look like many available for sale. Do the servos reprogram themselves if removed or replaced, or is there some method to follow?
Old Mar 25, 2023 | 11:57 AM
Parker 7's Avatar
9 volt battery test before taking anyting apart?
The position sensors will know exactly where they are at as you rehook up
Pic coming
If you take this pic with the green line splitting the top portion as the second diagram on page X
and the bottom portion as the first diagram on page X
The top portion is for the center vent and side dash vents containing your center vent servo , located car's right
The top portion has on the very rear ( front of the car ) the windshield defog servo , located car's left
The center vent grill pops straight out but you might want to leave it alone as the louvers breaks
You can stick a pencil in it to gauge the center vent door moving or a flashlight , you should hear it
Old Mar 25, 2023 | 12:37 PM
Parker 7's Avatar
This is your lower portion
Genuine Air Conditioning And Heater Unit For Jaguar Xj 1995 - 1997 (from 720125 To 812255) Classic | Jaguar Land Rover Classic Parts
Upper portion coming
Search Genuine Air Distribution/ducting Parts For Jaguar Xj 1995 - 1997 (from 720125 To 812255) Classic | Jaguar Land Rover Classic Parts
Compair your part #s between different servos as I think they are different
Old Mar 25, 2023 | 12:46 PM
Parker 7's Avatar
Defrost vent servo #
JLM11963
JAGUAR DAIMLER FACE LEVEL AIR DUCT SERVO MOTOR X300 DENSO 063700-5452 JLM11963 | eBay
Question on the sellers labeling as center vent servo
Old Mar 25, 2023 | 01:35 PM
Parker 7's Avatar
Your windshield defrost vent servo is on the car's left
and the center vent servo on the car's right
You can follow the servo's linkage and door's pivot points
Old Mar 25, 2023 | 01:52 PM
brianhough's Avatar
According to: Search Genuine Air Distribution/ducting Parts For Jaguar Xj 1995 - 1997 (from 720125 To 812255) Classic | Jaguar Land Rover Classic Parts
It looks like the face vent servo is on the right side of the hvac box. I'm assuming the whole dash would have to come off for that. I guess my only option short of that would be to hook a 9 volt to those two pins like you mentioned earlier and hope to close off the face vent. I think it's preventing the defrost door from opening. I set it to the floor vent, and I still feel a fair amount coming out of the center/face vent.
Old Mar 25, 2023 | 02:27 PM
brianhough's Avatar
I found a post by smartobject where the center/face servo can be got at by removing the glove box and some other bits and bobs. Somewhat daunting, but not as bad as removing the whole dash!
Thanks so much Parker, your input really helped. I'll post an update when I get further.
Old Mar 25, 2023 | 02:38 PM
Parker 7's Avatar
Keep careful track of your hardware on the glovebox removal
I can see the center vent door blocking the windshield defrost door and only giving you a center vent servo code
9 volt battery can drive it out of the way and you may get your defrost back
You may be able to do this without removing the glove box if you can reach the ECU connector
Once the center door is out of the way the system may reset to just like normal as it had a hickup
I have an error in the pin #s will have to clean up
Old Mar 25, 2023 | 03:27 PM
Parker 7's Avatar
Got a picture of my intalled climate control ECU with connector off
Pic coming
Not the correct pic , still looking as I just took it
This pic is with connector in hand with the connector spot above my finger
The ECU is mounted against the center console wall
This pic shows the ripple on the perimeter of the connector shell where the ripples mount the ECU pointing car right , so this is a rotation after a release button on the car;s right wire loom clockwise to ypu
Now the numbering
Your corrected center vent servo motor pins are......................................
7 and 20 , so my post # 2 is correct
Old Mar 25, 2023 | 04:55 PM
brianhough's Avatar
So Hook a 9 volt to pin# 7 and 20 and see if center vent closes right?
Old Mar 25, 2023 | 05:15 PM
Parker 7's Avatar
Yep . just swap polarity to run in the other direction
listen as they are hard to hear
Old Mar 25, 2023 | 05:24 PM
Parker 7's Avatar
Your windshield defrost servo will be pin 6 and 19 of the same connector
This is marked as light blue in my above chart post # 2
One of the 2 servos in question should run
benzjag
Jun 21, 2022 08:26 PM
Legend
Aug 24, 2016 02:33 PM
JonFleming
Jun 18, 2016 12:35 PM
Muleears
XJ40 ( XJ81 )
Dec 8, 2010 05:09 AM
jagnut1025
Sep 24, 2009 05:14 PM
