Airbag Diagnostic problem
Old Jun 18, 2023 | 11:40 AM
ginger12's Avatar
Default Airbag Diagnostic problem
Hello from germany,
i want to do diagnose on my XJ 300 1995 3.2
I have the CD from 1997 and 1999. I have problems to read the airbag system so i cant find the trouble codes.
I have changed all parts in the system like airbag moduls,crahs sensors and and. Checked the cables. I cannot find whats wrong. Now i got the PDU and was happy but it doesnt work with this cd. In genrell is it possible to get in the airbag system and find the trouble codes?
Does anybody has some fotos to show me how to connect the cables on the MPA and base station?
I will be very happy if anyone can help me !
best regrds
michael
Old Jun 18, 2023 | 12:44 PM
Parker 7's Avatar
Brendan made a PDF of X300 airbags for dummies for an overveiw of the system and trouble shooting
Lately it seems to be the safer fuse the culprit
File coming
Old Jun 19, 2023 | 12:42 PM
ginger12's Avatar
Default Jaguar Diagnosis reviews
Hello,
many thanks i have this file and it doesnt help me that time.
regards
michael
Old Jun 19, 2023 | 12:52 PM
Parker 7's Avatar
The safer fuse is in the main blue color airbag module under a square cover
Someone posted a picture of his
Looking
Diagnostic equipment can't see everything
Old Jun 19, 2023 | 02:53 PM
Parker 7's Avatar
If yours gets to it this is a pic of the safing fuse under the white rectangler cover
See link below
Airbag/SRS Safing Sensor - Jaguar Forums - Jaguar Enthusiasts Forum
Old Jun 19, 2023 | 03:39 PM
BlackSpeed66's Avatar
I know nothing about the diagnostic equipment as I do not have access to any.
I do recommend attempting Brendan’s DIY for the airbag system diagnosis as I was able to successfully repair my ECM unit recently. If you have a decent volt/Ohm meter, just follow it step by step and take your time.
Old Jun 19, 2023 | 03:49 PM
Parker 7's Avatar
Important to use test resistors not less then 2.5 ohms as used in Brendan's doc
No direct meter test leads on airbag connectors least they blow as designed
Old Jun 20, 2023 | 12:40 PM
xalty's Avatar
cluster stores airbag dtcs
if you use a test light on the airbag light line i think it will flash out. otherwise put a module from a taurus and it definitely will
Dante Guthrie
Oct 31, 2020 01:57 AM
Lady Penelope
Apr 8, 2018 12:51 AM
neo4star
Jul 15, 2017 07:57 AM
Magnumforc
XF (X260)
Jun 14, 2016 10:47 PM
apollo022777
Apr 16, 2008 07:56 PM
