Any Recommendations For Obd2 live data reader and Multi meters
Old Apr 27, 2017 | 07:07 PM
vandenplas408's Avatar
Default Any Recommendations For Obd2 live data reader and Multi meters
need to buy
a decent Obd2 live data reader for jag vdp 96 4.0 usa
and a good multi meter as well
I dont want another crap harbor frieght tool lmao
Old Apr 27, 2017 | 07:46 PM
JBzXJ40's Avatar
Not sure about a OBII live data reader, but Fluke is a very good brand for multimeters.
Old Apr 28, 2017 | 01:06 AM
Qvhk's Avatar
On OBD scanners, lots of info with with members' experience and recommendations in another section of this Forum:
OBDII Code Scanners ** Member Approved **
https://www.jaguarforums.com/forum/g...-%2A%2A-33347/
Old Apr 29, 2017 | 09:02 AM
i just could not find any refernce to a reader that has all live data features working
Old Apr 29, 2017 | 09:08 AM
http://www.jcwhitney.com/1996-1997-jaguar-xj6/equus-obd2-can-code-reader-for-vehicles-built-after-1996/p2011281d50005y1996-1997j1.jcwx
Old Apr 29, 2017 | 12:24 PM
Lady Penelope's Avatar
You won't find this in the auto parts store . I recommend one that has the software disk . Note they are for USB to laptop or bluetooth to your smartphone but not both . I recommend USB
ELM327 v1.5 USB Interface OBD2 Auto Car Scanner Adapter Diagnostic Tool Cable MY | eBay
See video at about minute 3
As to meters you cant go wrong with a Fluke but I also use the old school needle type in my field for it has its merits .
Thanks , Joe
Old Apr 29, 2017 | 02:27 PM
i have a crap laptop. ill check specs.
this works with my car? live data?
Old Apr 29, 2017 | 02:47 PM
Yep and Yep , all you need is a USB port which you most likely have . The ELM327 also has the traditional check engine light codes plus code reset . Private Mail me for I have some more for you
Thanks , Joe
Old Apr 29, 2017 | 04:17 PM
at work. but will do. thanks so much. want to get down on that live data
Old Apr 29, 2017 | 05:38 PM
Make sure you go to live graphs mode on the software as you can " see " it better . Private Mail me for more as well as seeing if my settings work
Old Apr 29, 2017 | 06:31 PM
almost off work will pm shortly. i can not wait to get down and make this a sex beast again
Old Apr 30, 2017 | 01:12 AM
im going to order the obd2 reader and test it out
