Battery/ Electrical woes
Old Oct 9, 2015 | 04:14 AM
MikeColl's Avatar
Default Battery/ Electrical woes
Help needed. just bought a 1995 XJ6 4.0l with an electrical fault. (price paid reflected this.
The seller had identified an ECU water issue as the footwell ECU had been removed and the connections were oxidised. I have cleaned these up and opened the ECU which appears sound inside.
The issue is that when I connect the battery (with or without the said ECU hooked up,and with or without ignion on) there's no power to anything, indeed the battery discharges immedietly, I have also tried a known good battery with the same result. Instant discharge although the readings recover upon disconection.
Any ideas?
Old Oct 9, 2015 | 04:30 AM
Welcome to the forum MikeColl,
I've moved your question from General Tech Help to X300 forum. Members here with the same model will be able to help.
Old Oct 9, 2015 | 04:53 AM
MikeColl's Avatar
Old Oct 9, 2015 | 05:48 AM
RJ237's Avatar
Apparently you have a short to ground. I would start by disconnecting the power lead to the alternator.
Old Oct 9, 2015 | 06:45 AM
b1mcp's Avatar
Yes I agree with RJ.
And I would suggest that while investigating and checking that you use a multimeter to test for no continuity between + and - battery leads before reconnecting a battery.
Old Oct 9, 2015 | 01:44 PM
sparkenzap's Avatar
After following the advice above, if you still have indication of a short in the power circuit, you can put a fairly high power lamp (like a headlamp) in series with the positive lead of the battery. That way, you can have current flow and not burn up anything including the battery. If a high load is there, the lamp will light. Disconnect fuses, relay, and wires until the lamp dims or goes out and you have found the offending circuit.
Old Oct 9, 2015 | 03:08 PM
Tipptone's Avatar
Hey sparkenzap that's a good new one for me. Thanks!
Old Oct 10, 2015 | 01:04 AM
MikeColl's Avatar
Many thanks.
Old Oct 10, 2015 | 01:05 AM
MikeColl's Avatar
Yes, thank you.
Old Oct 10, 2015 | 01:06 AM
MikeColl's Avatar
Yes, thanks.
Old Oct 10, 2015 | 06:07 AM
rads's Avatar
Instant discharge? If your battery is any good an "instant discharge" is going to melt something, hopefully a fuse first! If no fuse failure I suggest the battery is dead, or, not "instant discharge". What do you measure which leads you to your observation of "instant discharge"? a voltmeter on the battery terminals?
Old Oct 10, 2015 | 11:15 AM
MikeColl's Avatar
Default Discharge
Hi, this is what I use. it check condition at rest and under load My battery if fine disconnected but flattens the momenr I connect the car lead. Also me "booster pack" does the same.
Attached Thumbnails Battery/ Electrical woes-%24t2ec16z-ee9s2uipfcbrzfb2tiyw%7E%7E60_12.jpg
Old Oct 10, 2015 | 12:29 PM
RJ237's Avatar
That is probably a battery with a bad cell. A good battery can not possibly discharge to dead when connected without first melting the cables.
Old Oct 10, 2015 | 02:33 PM
Don B's Avatar
Hi Mike,
Welcome to the Jaguar Forums!
You've already received excellent advice from some of our experts. I would add that, if you don't already have it, you can download the 1995 XJ Electrical Guide here:
http://www.jagrepair.com/images/Auto.../jagxj1995.pdf
The guide contains all the wiring schematics, component location diagrams, etc., which should help narrow down areas where battery power shorts might occur.
Cheers,
Don
Old Oct 11, 2015 | 03:07 AM
MikeColl's Avatar
Originally Posted by Don B
Hi Mike,
Cheers,
Don
Thank you thats a big help, I'm used to the electrics on motercycles (have a couple) and some older cars (Land Rovers etc) but wow, these Jaguars take wiring to a new dimension. Will post pics today (of the car) in "introduce yourself).
Thanks all for your help. Still scrathing my beard. Still no power being fed to ant electrical curcuits on the vehicle. Suspect a main fuse so the wiring diagram will help a lot.
Old Oct 11, 2015 | 10:24 AM
cool's Avatar
Correct
Malihide
Apr 2, 2016 04:05 PM
leep123
Sep 26, 2015 04:53 PM
Pilotman11
Sep 18, 2015 11:35 PM
Boeingtravel95
Sep 14, 2015 05:01 PM
thefixer
Sep 11, 2015 09:17 PM
