Best source for suspension bushings?
Old Feb 24, 2023 | 05:57 PM
baws's Avatar
Default Best source for suspension bushings?
All the front rubber bushings on the '97 XJ6L are shot.
Is there a kit available from one of the major vendors that is comprehensive and of good quality?
Old Feb 24, 2023 | 06:37 PM
Parker 7's Avatar
Can't speak for them but they have a reference map and density comparison chart
silicon spray while assembling for no squeak ?
Jaguar XJ6, XJ6R - X300 - X306 (1994-1997) Replacement Suspension Bushings (powerflexusa.com)
and
See also for parts name and referencing
Genuine Wishbone-upper And Lower For Jaguar Xj 1995 - 1997 (from 720125 To 812255) Classic | Jaguar Land Rover Classic Parts
If you look at item # 13 you may see daylight through it while still on car
You can pour your own bushings as the material is availble on E - bay and Amazon
Old Feb 24, 2023 | 07:57 PM
baws's Avatar
Thanks again Parker.
I'm used to vendors like Moss who have listings in their catalogs for the older, more "classic" Jags.
It seems harder to find decent bits for the newer cars like the X300.
Old Feb 25, 2023 | 12:50 AM
SleekJag12's Avatar
Don't count on Powerflex to get anything right. They are sloppy. I and others have had bad experience with them. Their fit is often not right. Check this instead:
https://www.polybush.co.uk/polyureth...aguar/xj-x300/
They are my next go-to when I need some bushings (which I do). Their bushings are confirmed to fit by Brendan @b1mcp and they have complete kits. They are more focused on Euro cars.
Old Feb 25, 2023 | 01:42 PM
baws's Avatar
Thanks Richard. Looks like that vendor has the kit I was looking for.
I will contact them.
Old Feb 26, 2023 | 11:42 AM
bjarnetv's Avatar
if your in the US the best bet is probably https://www.sngbarratt.com/English/#...?saveBranch=US
not sure if they offer kits, but they probably have all the OEM bushing available.
Old Feb 26, 2023 | 11:55 AM
baws's Avatar
I did check SNG Barratt but saw no kits listed. I will try calling their USA branch.
Thanks!
Old Mar 3, 2023 | 09:15 AM
2manycats's Avatar
Thanks!
I installed Polybush bushings on my 97 LWB. Great improvement.
1. Get the part numbers from Polybush site HERE
2. Search SNG US Site for the part number. Example HERE
S-Type Owner
Sep 25, 2022 03:40 PM
VR6Guru
Feb 25, 2018 02:18 PM
philc850
Aug 13, 2015 11:34 PM
04xtype04
Mar 9, 2014 05:34 PM
jgallant
Apr 7, 2011 04:11 PM
