Bluetooth conversion of OEM X300 radio?
Old May 7, 2026 | 11:37 AM
JensenHealey's Avatar
Default Bluetooth conversion of OEM X300 radio?
I happened to see a mention of someone who does a bluetooth conversion of the OEM radio in the X300 on a "book of faces" post.
However there was no mention of actual contact info other than to say this could be found on evil-bay
I have searched there for "Jaguar radio bluetooth" but so far I have not found anything.
Anyone know anything about such a conversion?
I have in the past put an aftermarket radio in a XJ40 car that I own but I was never satisfied with the look of the resulting change in radio head units.
Old May 8, 2026 | 06:33 PM
Parker 7's Avatar
Bluetooth transmission is missing the full input signal ( this has to do with data or refreash ( ? ) rate ) so a direct inline plug is better
There or some post on the inline jack you can solder in ( original Jaguar head ) losing the cassette function
Old May 8, 2026 | 10:21 PM
Are you saying that others have made posts about how to solder in an aux jack in place of the cassette function?
Old May 9, 2026 | 03:14 PM
Parker 7's Avatar
Yes
Old May 11, 2026 | 06:45 AM
jmstunts's Avatar
Old May 11, 2026 | 06:44 PM
olivermarks's Avatar
https://www.discountcarstereo.com/bt2-jag97.html
https://jagaux.com/
Old May 12, 2026 | 08:27 AM
Thank you everyone who has replied to my post. This information is very useful.
Old May 12, 2026 | 11:48 AM
Parker 7's Avatar
The other mod is tapping into the cassette circuit with a jack soldered into the cassette head pickup , this will be your free input line this is direct with no signal loss or compromise but losing the cassette . This is no cassette device insert but you place a tie wrap on cassete carriage inside to mimic the cassete needs to be alive
Marks device will plug into the 8 pin DIN plug at the original head and if you have the external in the trunk final stage amplifier ( premium Jaguar stereo option ) you would loss that and would have to use the original built speaker outputs coming out of the rear AJ9500A
Old May 17, 2026 | 10:03 AM
Thanks Parker
Is there any additional info or maybe write-ups with detail photos of how to do that?
BTW, I did search for "solder aux jack" and "solder jack radio" in this forum and nothing showed up.
Is the same radio head unit used in the XJ40 and maybe these details were posted in that forum?
KC XK8
Sep 7, 2025 03:44 PM
Dreamjags
Jul 30, 2024 06:03 PM
Rishi
Jul 13, 2024 03:52 PM
Phil Dixon
General Tech Help
Jan 17, 2023 03:22 AM
