Cabin Filter? 97 xj6L
Old Jun 19, 2024 | 09:08 AM
Jagicon's Avatar
Default Cabin Filter? 97 xj6L
Hi to every Jag lover! Hope everyone is staying cool. Can someone tell me if he 97 xj6L has a cabin filter that I can change ? Never thought about this before but my daughter said the inside of my car smells old.. haha. Thanks in advance! Love my Jag!
Old Jun 21, 2024 | 08:21 PM
motorcarman's Avatar
Jaguar addressed this issue a few decades ago.
File Type: pdf
Old Jun 22, 2024 | 09:32 AM
Jagicon's Avatar
Wow! Thank you for this information. I wonder if Jaguar dealer would help with this or if it was ever done already. I"ll show it to my independent jaguar service guy and see if he is willing to check this out. Honestly, it doesn't really bother me and until my daughter said something I never really noticed that much. I appreciate your reply..
Old Jun 22, 2024 | 12:08 PM
I remember we also had BG products and FRIGI FRESH was one of the products we used as a quick freshener.
Old Jun 23, 2024 | 09:06 AM
Jagicon's Avatar
Thanks again! So great to have this forum.
Old Jun 26, 2024 | 12:47 PM
cdma's Avatar
I wonder if there is a substitution for JLM 20000. I am sure I can get the tool through the Jag association
Old Jun 26, 2024 | 06:11 PM
PBoudr's Avatar
I usually get a smell before I kick the AC on when the car has been sitting in the sun for a while. It clears up very fast after the blower comes on.
I've seen videos of people injecting cleaner through the condenser drains. When I was under the car a couple of weeks ago I took a quick look to see if I could locate them but I didn't see them. Is there more than one? Based on where I see the water dripping I'd say they are nearer to the right side.
Old Jun 27, 2024 | 07:47 AM
Jagicon's Avatar
HI...thanks for this info. Plan to bring the car to my tech in 2 weeks and I'll ask him to look at it all. I have this image in my head of a filter that is decades old! haha. Makes sense that there would be a way to clean it out though.
Old Jun 29, 2024 | 08:48 PM
SleekJag12's Avatar
To answer the original Q, no there is no cabin air filter in USA cars. Apparently German cars originally had one. I wish they all did.
The musty smell is made worse because the heater valve opens when the car is shut off (it needs power to stay closed). So heat from the hot coolant can migrate into the heater core after shut off. Then there is moisture from the A/C condenser in there which is not a good combination.
So the cabin air filter would not really solve this "problem," there needs to be a closed valve on the heater core pipes when the engine is off. But it was not designed this way.
@PBoudr The condensate drain tubes should be found on both sides of the transmission under the vehicle, and the connections at the evap core should be seen up in the corners of the footwells. I believe they can be carefully pulled off to make sure they are clear.
Seems like a good idea to treat the core from below, that should help.
Old Jun 30, 2024 | 10:52 AM
Jagicon's Avatar
Hi and thank you for your answer. So, the 97 xj6L is a USA car. I thought this year/model was foreign. Someone/something must have given me that idea. But it's good to know for sure. I'm glad there is no filter. I can ask my Jag guy about checking the drain tubes to be sure they are clear. I love learning about my car so thank you again to all.
Old Jul 1, 2024 | 03:10 AM
SleekJag12's Avatar
Well Jagicon, your car was made for the USA, with emissions, bumper specs, and the steering wheel on the right/left/wrong side. But ALL these cars were built in Coventry, England. So that is "foreign" to us. Check the car's birth mark stamped into the metal between the spare tire and the battery. It is not a USA VIN!
Though I consider the Brits as family, given my heritage and Jaguar experience, of course. Not to mention our countrys' historical affiliations.
Old Jul 1, 2024 | 10:47 AM
Jagicon's Avatar
What an awesome explanation to keep in mind. It's just something I don't really think about until it comes up for a reason. Thank you for writing back on this. I really think that my jag is the best ride I've ever owned. However, I worry about not being able to get parts or someone who knows what they're doing to service it. I have someone about an hour away that does know Jags but it's still inconvenient. This is my primary car. I really enjoy it and that means something. Your x150 must be a beauty!!
MRomanik
Sep 2, 2022 09:50 AM
2018XF25T
F-Pace (X761) / C-X17
Jun 12, 2022 08:03 AM
Jagst
Feb 20, 2016 05:25 AM
MRomanik
Aug 20, 2012 01:04 AM
itspec60
Jun 28, 2010 09:08 PM
