Check Engine Light
Old Oct 22, 2010 | 10:26 PM
jhxj6's Avatar
Default Check Engine Light
I do know that when a Jaguar check engine light comes on it means that there is a problem with the fuel system but I don't know what exactly it means. What are some things I should check for when the light comes on? Mine just came on.
________
VAPORIZORS
Old Oct 23, 2010 | 01:59 AM
Doug's Avatar
There are actually a couple hundred possible faults that could trigger the light. Best bet is to buy a code reader ($50 or so) and see what codes have been set. Knowing the code will get you started in the right direction
Old Oct 23, 2010 | 10:09 AM
TopHatChef's Avatar
If you don't want to buy a code reader, a local auto parts store may lend you theirs. I know Advanced Auto should have one that you can borrow for 5 minutes in the parking lot. Make sure you write the code down, and let us know what it was.
BrentGardner
29
Dec 16, 2024 12:13 AM
big d
Sep 3, 2015 07:37 PM
niner nellie
Sep 1, 2015 10:53 PM
tony bosco
Sep 1, 2015 02:06 PM
daro31
Aug 27, 2015 09:26 AM
