constant Code P0300
Old Jun 29, 2012 | 06:14 PM
jagclaude's Avatar
Lightbulb constant Code P0300
1995 XJ6 VDP
I have a constant code P0300
Car starts beautifully
Car iddles beautifully 750 RPM
When hot between 2000 and 2500 RPM sometimes the engine is "holding" its power but if I step on it it goes superbly well.
I have replaced the coils,
I have switched the coils from cyl 1 to 2, to 3 and so on
Still get the code P0300
Any idea about this?
Ideas are welcomed
Claude
Durham NC USA
Old Jun 29, 2012 | 08:57 PM
motorcarman's Avatar
I had a customer car for a misfire code and found AC Delco plugs installed.
I replaced and moved a few coils but the problem was the plugs!!!!
I replaced with Champion RC12YC and fault was fixed.
Sometime it is an easy fix???
bob gauff
Old Jun 30, 2012 | 09:10 AM
jagclaude's Avatar
Too bad you are so far from NC !
I am going to look at the plugs right now (just cmae back from the parts store to get the spark plug socket)
Will let you know shortly
Claude
Old Jun 30, 2012 | 11:35 AM
jagclaude's Avatar
Saturday noon
Dear Bob,
Went to get the Champion's
Found 6 Autolite installed in the engine with a gap as wide as the Golden Gate Bridge but all nice, clean and greyish.
Installed the Champion's
Car seems to be running better and iddling dropped down from 800 to about 650.
But, but code P0300 is still there
I do have 2 extra coils and I am going to play "musical chairs" with them and see if I can get rid of that code or not.
Will let you know again.
Claude
Old Jun 30, 2012 | 04:42 PM
jagclaude's Avatar
Hi again,
After playing musical chairs with the coils (I have 8 of them in total) it is still the infamous code P0300 but I am using only a simple small OBDII
Car is starting perfectly
Car is iddling perfectly cold or hot
car is running more or less OK excepted with that "witholding" feeling between 2000 and 2500 RPM, it feels like it would be missing gas but if I step on it no problem.
Should I look in the direction of the intake and injection/injectors area ?
Any idea is most welcomed.
Claude
P.S. Gas mlileage is very bad
Old Jun 30, 2012 | 06:12 PM
Doug's Avatar
Any of the coil wires or connectors look damaged? And I think I heard the #5 and #6 connectors are often accidentally attached to the wrong coils.
Old Jul 1, 2012 | 10:22 AM
jagclaude's Avatar
Dear Doug,
Thanks for pitching in.
Obviously I have looked into this and tested each coil, one by one, removing the wire and making the engine run on 5
Then I have checked visually at night too (like you had suggested back in May)
I know I have only a simple OBDII tester and most probably a more sophisticated one would give me more info.
But as said yesterday I am going to (try) to investigate toward the fuel delivery.
Unfortunately I can do anything with good old Webers or a good old Ferrari 12 cyl or an old Carrera 4 cams or an old XK 150S to rebuilt from A to Z but all this electronic junk leaves me paralyzed
Even the official Jaguar books are worthless. NOBODY can tell me (neither the Jag books) what triggers the interior lights when you open the driver's door or where is (if any) the memory module for the seat/steering wheel/outer mirror.
I am quite sure that most Jag dealers don't even know themselves neither.
Thanks agian for your input. I really appreciate it
Claude
Old Jul 1, 2012 | 11:03 AM
limegreenclown's Avatar
Are you looking for the button that controls these items or the switches? I know of a few wiring diagrams that are pretty vague on location but a tiny bit helpful, although you have to do some code breaking. Also, I recently did fuel injectors because I thought one was bad, possibly causing my misfire, and later found out I had the coils hooked up backward on #5 and #6. The fuel injectors were not as expensive as I had feared, costing 179 USD rebuilt off eBay, and they definitely work. Don't know if this makes the operation less scary, but at least you have a figure to go by??
Old Jul 1, 2012 | 11:09 AM
Doug's Avatar
Good, because I may need your help. I take care of a slew of old cars like that.....and am often lost.
Each door latch has it's own miniature switch. You have to remove the latch, as I recall, to even see it. It's roughly .625" square with a tiny plunger button.
What problem are you having?
Don't take mine as the final word but I don't there is a stand-alone "memory module". I think the memory storage function is incorporated into the driver's door switchpack .
philwarner
Oct 4, 2024 01:37 PM
Rivguy
Nov 13, 2022 02:55 AM
philwarner
25
Jun 26, 2021 05:43 AM
CaneCounsel007
Nov 13, 2015 09:05 PM
axr383
Sep 12, 2015 01:32 PM
