Coolant Problem in 1995 XJ6?
Old Nov 2, 2013 | 11:40 AM
Dexter Adams's Avatar
Default Coolant Problem in 1995 XJ6?
Hello,
Yesterday night I was driving and noticed my coolant was low, so I continued driving and reached my destination. I checked my coolant and it was gone. So, I poured more in and then a mile later, my engine was smoking. I opened the hood and there's no coolant in it.
Long story short, I had my car towed to the auto shop. Any ideas as to what he problem may be?
Thanks so much,
Dexter
Old Nov 2, 2013 | 12:32 PM
Doug's Avatar
I suspect you have a coolant leak....faulty hose, most likely.....and the "smoke" is actually steam.
Old Nov 2, 2013 | 02:21 PM
Its a hose or the actual radiator? Also, I suspect a hose is easier and cheaper to fix...correct?
Old Nov 2, 2013 | 02:59 PM
Doug's Avatar
That's for the repair shop to determine. Could be either.
Almost certainly.
Old Nov 2, 2013 | 03:03 PM
Ok thank you. Could it be leaking out of the hose even if there's no pressure in the hose and he engine is off?
Old Nov 2, 2013 | 03:09 PM
Doug's Avatar
Yes.
Often a small leak won't manifest itself unless the system has pressure....but a big leak will allow coolant to pour right out regardless of pressure.
Old Nov 2, 2013 | 04:25 PM
ok.
Thanks much, I'll let you know what the mechanics say.
Old Nov 5, 2013 | 08:29 PM
Ended up being multiple hoses leaking and an obliterated water pump. Not worth the repair bill.
Old Nov 5, 2013 | 08:31 PM
Shame thanks for coming back and posting though.
Best
Jim
Old Nov 6, 2013 | 05:24 AM
SleekJag12's Avatar
That's only $300 or so in parts if you can do it yourself! That makes all the difference. It is such a nice car to cruise in, as long as you can work on it when it needs it. Plenty of help on this forum too, if you are so inclined.
BTW Doug, you are very kind...
Old Nov 6, 2013 | 05:51 AM
OWRltd's Avatar
These are just routine repairs that any car will require.
Raul Lara
Sep 14, 2015 07:31 PM
Bcrary3
Sep 3, 2015 03:48 PM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
Raul Lara
Sep 2, 2015 05:23 PM
OkieTim
Sep 2, 2015 12:48 PM
