crank position sensor X300
Old May 27, 2009 | 06:43 AM
cooke's Avatar
Default crank position sensor X300
Where is the crank position sensor on a 96-97 XJ6 (X300)
Old Jun 1, 2009 | 12:33 AM
cooke's Avatar
Originally Posted by rvf
At the front of the engine by the pully one 6mm bolt holding it in place.
rvf
THANK YOU
cooke
Old Jan 12, 2017 | 08:49 AM
Jdogsofla's Avatar
Which pulley? Any one have a pic or a diagram? Thank you!
Old Jan 12, 2017 | 09:08 AM
Qvhk's Avatar
Default Location of X300 Crankshaft Sensor
Check out pictures in post #330 of the following thread:
https://www.jaguarforums.com/forum/x...-66536/page17/
Old Jan 12, 2017 | 09:14 AM
b1mcp's Avatar
Save
Old Jan 12, 2017 | 02:11 PM
Jdogsofla's Avatar
That's perfect! Thanks you so much! I'm hoping that's my fix.
Old Jan 19, 2017 | 01:54 AM
Tcasmarcus's Avatar
I just changed the crank position sensor and i have a question.. the cable end of the sensor with the electric connector is attached to a plate with 2 bolts. When I removed this plate some oil dripped out... What is this "hole" behind the plate? 😶
Old Jan 19, 2017 | 02:23 AM
The end of the auxillary jackshaft.
I use a good smear of Hi-Temp RTV on that plate, and refitted it.
There is NO seal in there, but a gasket for that plate NBB2119AA I think???
#6 is the plate in question.
Old Jan 19, 2017 | 02:27 AM
Tcasmarcus's Avatar
Ah yes exactly! Thanks for the clarification. 😀
Old Jun 30, 2018 | 08:15 PM
sbierwagen's Avatar
Just changed mine, and the sensor was retained with a bolt that had a 8mm hex head. Might have been a 6mm shaft, but the fastener head was of more immediate importance to me at the time.
Detaching the connector was lightly counterintuitive-- the sensor side is stationary, clipped to a retaining bracket, and the harness side is loose. Yanking on the sensor side of the connector doesn't help you none.
mrplow58
Jan 21, 2024 05:53 AM
RoyLittle0
May 25, 2023 02:38 AM
Forcedair1
Feb 19, 2020 01:51 PM
joesoap
Sep 10, 2015 01:09 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
