Cruise control removal
Old Jan 8, 2018 | 06:33 AM
Mark Murphy's Avatar
Default Cruise control removal
Hi Guys and Girls, since i have never trusted cruise control, i dont use it, so i want to remove it, what do i do with the vacuum side of things?
Old Jan 8, 2018 | 10:06 AM
Ric in RVA's Avatar
Just ignore it?
Not going to affect anything under the hood. If not just cap off all the vacuum lines with caps.
Mine works great....use it all the time.
Old Jan 8, 2018 | 10:49 AM
Vee's Avatar
Vee
Lucky...its the only thing that has never worked for me. I have swapped out the brain, the vacuum pump and checked for leaks...nothing.
I've never taken the switch apart though...
Old Jan 9, 2018 | 11:41 AM
Qvhk's Avatar
My 1995 XJR Hong Kong car does not have cruise control; wish it had one fitted. Wonder if retrofitting is possible.
Old Jan 9, 2018 | 12:14 PM
sogood's Avatar
As far as I'm aware, cruise control can be retro fitted. The wiring and plugs should be there, though I may stand corrected on this. There was a thread on here quite some time back regarding this topic. A search should unearth it.
I enjoy having the added benefit of cruise control. It makes for more relaxed motorway driving and avoids the possibility of accidentally speeding. The easiest, simples way of "removing" cruise control is just not to switch it on!
Old Jan 9, 2018 | 12:52 PM
Qvhk's Avatar
Found:
Cruise control retrofit project
Are (all) X300 pre-wired for cruise control?
sweatyfox
Jan 19, 2017 01:10 PM
1100me
Feb 16, 2014 04:17 PM
fritzvis
Jun 25, 2013 02:23 PM
annajj
Sep 9, 2010 04:23 PM
