Engine bay always live power.
Old May 10, 2016 | 02:22 PM
Harry Dredge's Avatar
Default Engine bay always live power.
Hey all, I recently got some under bonnet lights from an xj40 which I'd like to out in my x300.
I don't think they ever came on this model but I'm going to install them cause I think they are pretty cool. And I often work out outside in the dark.
So does anyone know a handy place to find always live power in the engine bay? Before I go crazy with the multimeter.
Thanks in advance!
Harry
Old May 10, 2016 | 03:27 PM
Doug's Avatar
On my X300 there was a small relay box/fuse box/junction point on the LH inner fender. It had a 12v constant junction post. I think there's a similar box on the RH side as well....but I'm a bit foggy on that.
Old May 10, 2016 | 09:56 PM
Doug is spot on.
Each under bonnet fuse box has a battery live posts under a rubber cover on the "engine side" of each of those boxes. Just look down the side of each box, and you wil see it.
I use one of them to charge the battery whilst its in storage.
Old May 11, 2016 | 03:25 AM
Awesome thanks guys! I'll post a picture when it's done.
Not the most exciting project but somewhat useful. I'll wire them to a switch so I can turn em on if needed
Old May 11, 2016 | 04:38 AM
rads's Avatar
Personally I'd wire a fuse in before the switch, too, as the supply to the fuseboxes is fused at 250A I think. If you accidentally shorted your light the light wires could melt. Alternatively you could look for a permanent battery supply which is via a fuse for something else.
oldemacdonald
Apr 18, 2016 07:31 PM
loftymk1
Apr 18, 2016 05:18 PM
Eurobahn Jaguar
F-Pace (X761) / C-X17
Apr 14, 2016 08:39 AM
Pierrick584
Apr 14, 2016 03:23 AM
oldemacdonald
Apr 14, 2016 01:36 AM
