Exaust backfiring, car now going fast when pressing gas....
Old Jul 27, 2011 | 01:05 PM
MLRocafella85's Avatar
Default Exaust backfiring, car now going fast when pressing gas....
hey everyone, I am experiencing a major issue... When i press my gas all the way down the exhaust starts to pop, and the car wont go any faster than 30-40mph. But when I accelerate slow it will go faster. It is only happening when I press the gas all the way down. Also, on idle if I rev the engine to about 30rpms or higher the exhaust will begin to pop, alsmot sounds like something it blocking it. I have just had a new tps sensor installed, a new MAF, and had a fuel injection service done. Drove fine on the way home, then when I got home I cleaned under the hood, went to take it for a spin and it started to backfire. Please help, thanks.
Old Jul 27, 2011 | 04:17 PM
Straight6DOHC's Avatar
What do you mean when you say you cleaned under the hood?
Old Jul 27, 2011 | 04:39 PM
all I did was spray some engine degreaser and ran some water around the engine bay, I may have gotten some water in the alternator and air pump, but other than that, that was it.
Old Jul 27, 2011 | 05:39 PM
I didnt mention, the other day my fuel rail housing broke, the part that holds the lines together. I crimped the line and had to replace the fuel rail and the pressure line. I also pulled all of the injectors and sprayed them with electronic cleaner. I then reinstalled everything. I also did the EGR Valve last week.
Old Jul 27, 2011 | 08:08 PM
sparkenzap's Avatar
hey, dude. You have wet the spark coils. Take the cover off (the one with "JAGUAR" on it) and remove each coil over plug coil and dry with a towel.
Do not "fix" anything else until you have fixed the problem!
Old Jul 28, 2011 | 05:29 AM
Hey just before doing that, it was completly dry when i opended the cover just after washing. I was checking connections.... All was dry on top, can the water enter another way?
Old Jul 28, 2011 | 04:28 PM
just to check in, I had a cylinder 4 misfire, and also had a p1314 code. Problem seems like its solved. I had a used Lucas coil I put in.
Old Jul 28, 2011 | 04:30 PM
Default P1314 Code, what does it mean?
hi everyone, driving today, I had a misfire on cylinder 4, as well as a P1314 code. It says Misfire Rate Catalyst Damage Fault Bank 2. Does this mean my cat is damaged? I swapped out cylinder 4 with a used coil and cleaned the code, seems all ok for now..... Just wanna know about the other code please, thanks.
Old Jul 28, 2011 | 04:39 PM
sparkenzap's Avatar
That code means that the engine is dumping so much raw gas that it will damage the catalyst if you keep driving it. It is indicative of a complete misfire. It is likely no damage was done if you drove for a short time.
Default Car shuts off in idle, hesitates on acceleration.... Please help :(
hi everyone for about the last month, I have had this problem urking my nerves. When I start the car, the idle acts kind of funny it stays around 10RPM but the engine makes a funny noise, like it wants to loose power. So when I go udner the hood and mess with the throttle, it feels like theres a slight delay after the throttle is pressed, not sure if thats normal? But anywho, if I keep pressing the throttle with my hand eventually the engine will stall and shut off. That is what is happening on idle. Now when driving, if I am at a red light or stop sign, and I begin to accelerate, the cars check engine light will turn on for a quick second or 2, the car will jerk and hesitate, and keep driving like there is no problem. If it jerks BAD ENOUGH, a transmission light will come on. And when this light comes on, the car begins to surge, like letting my foot go off the gas the car wont decelerate for a good 4-5 seconds, and when coming to a stop the RPMS take a few seconds to reach back down to 10.
I have went to a local shop that works on Jaguars and has the Jaguar software, and the gentleman pulled a tps code and a maf code. I replaced both, and the problem still exists. I have also changed the EGR Valve, fuel regulator, and fuel pump, no luck there. I have did a oil change, spark plus, 6 new coils, new valve cover and valve cover gasket set and a fuel filter and still seems like nothing is helping me. Has anyone experienced anything like this?? I was thinking the CAT Converter, but took it to a local muffler shop and they said the CAT Being so small, that it wouldn't cause problems like this. If anyone can help me out I would appriciate it, or send me in the right direction. Thank You, God bless
Old Jul 28, 2011 | 04:40 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
thedugger1
Sep 24, 2015 05:32 PM
TC Johnson
Aug 29, 2015 08:55 PM
Stuart S
Aug 29, 2015 11:37 AM
Vector
US Lower Atlantic
Aug 26, 2015 05:36 AM
